Head light bulbs are acting up
Discussion in 'Lighting' started by thewhiteknight, Jul 13, 2011.
  1. Jul 13, 2011 at 5:44 PM
    thewhiteknight
    thewhiteknight [OP] Well-Known Member
    Colby
    SW Alabama
    06 PreRunner TRD SR5 Dbl Cab
    foglight anytime, HIDs, lift, bilstein 5100s, AAL, LED interior, LEDs, BHLM, extended rear diff vent mod, upgraded audio system,
    I need some input on a problem.
    I have 2 blue LED headlight bulbs. 68 smd LED.
    Here are the scenarios
    1) I plug in the LED bulb and the stock bulb, the LED completely works.
    2) I plug in both LED bulbs and only half the smd chips light up and are VERY dim.
    3) leave one led bulb unplugged and leave other in it does nothing. They only work correctly if one bulb is stock and other is led
    ..the stock bulbs still work as normal
    Thanks in advance..
