Head light problems. No high beam
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04trd, Apr 13, 2013.
  1. Apr 13, 2013 at 2:54 PM
    04trd
    04trd [OP] Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Hey tw here's my problem. I have a 2004 dc yota with 132k. Recently I had a shop put in hids. They worked for 4 months now. Highs and lows working perfectly. got a new kit installed cause the old one was giving me problems like not turning on half the time and one light working while the other doesn't. Now the shop just called me saying I don't have any power going to the high lights. We took everything off and put it back to stock and still no power to the highs. We got power to the column and to the relay but we have no power to the high lights. Any one know a fix or ever have this happen fuses are good and no cut works. Any help would be great!
  2. Apr 13, 2013 at 4:45 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Yes I had the same thing happen to me and had Toyota confirm it because it was under warranty. Basically your headlight switch has a short and will need to be replaced. You should have your DRLs working, but when you pull the switch for the highlights everything goes black. The headlight requires you to break into the steering column, And I would put my money on it that the shop who did your HIDs shorted it out.
  3. Apr 13, 2013 at 4:57 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    My 04 never had dtrl but I will definitely look into it
  4. Apr 14, 2013 at 4:14 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Any one else have any idea where to even start to check stuff? If I have power at the column and at the relay under the hood I am assuming that means I have a cut wire some where?
  5. Apr 14, 2013 at 2:24 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
  6. Apr 14, 2013 at 4:03 PM
    Yamaha Dave
    I'm telling you it's the switch. If it was the fuse you would not have any ability to turn on the parking lamps. If you can turn the parking lamps on and off, but your highlights go off when you pull the switch, the switch is defective.
  7. Apr 14, 2013 at 4:22 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    My low beams work just not the highs. So I will look for a new switch and the high beam indicator doesn't work either
  8. Apr 15, 2013 at 9:15 AM
    Yamaha Dave
    Like I said the switch. When you pull the switch you will not have the blue indicator light up on the dash.
  9. Apr 15, 2013 at 11:51 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Shiiiiit! That switch is 400 bucks!
  10. Apr 15, 2013 at 1:03 PM
    Yamaha Dave
  11. Jul 13, 2013 at 11:51 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Hey kinda an update on what's going in. Got a new switch and still nothing. Everything is new. Hids. Ballasts. Fuses are good. Relays are good. I have no damn clue on where to look or even what to do?
  12. Jul 13, 2013 at 12:55 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    A few days ago I noticed my highs aren't working on my retros either. Connections are all good. Not sure what's wrong either.
  13. Jul 13, 2013 at 2:53 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Ya I'm at a loss. My next step is to return it all back to stock and send her to the stealer ship where ill have to cut off an arm and a leg to get it fixed than debate if I should put the hids on or not
  14. Jul 13, 2013 at 3:10 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    And too add to this when I pull the switch to just flash my high beams the lights go in. Not sure if they are the high beams or not but I'm completely lost at this point
  15. Jul 17, 2013 at 3:45 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    So here it is! My truck is all fixed up and back to stock. I talked to the guy who worked on my truck and he said that when tacos go from high beams to low beams the voltage changes between them. He said how they installed them it was only getting the low voltage side or the low beam. Guess what I have learned from this is DON'T KNOCK STOCK! And don't always think that a high end audio installer is always right installing stuff. But thanks tw for all the help!
  16. Jul 19, 2013 at 7:20 AM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    This just goes to show that a relay harness is one of the first things you should do when you get your retrofit done/any HID install ;)
    Good on you OP for getting it all figured out!
  17. Dec 19, 2013 at 5:38 PM
    SMG
    SMG Member
    Nova Scotia
    2022 TRD Off Road Premium
    OEM LED Headlights, TRD Pro Taillights.
    Hey guys,
    The high beams just stopped working on my 04 TRD tonight. The lights don't work when you flick the stalk forward and there is no blue indicator. When you pull the stalk back all the way (flash) the high beams come on no problem and the indicator comes on. Any ideas? Any help would be much appreciated!
  18. Dec 19, 2013 at 5:43 PM
    joes06tacoma
    Joe
    Central Coast, CA
  19. Dec 9, 2018 at 12:30 AM
    blondi.josh
    blondi.josh Member
    Josh
    2017 Tacoma TRD Off-Road
    Nothing yet!
    Did you ever find a solution? My 2017 has exact symptoms and have been trying to fix this for nearly a year now - FYI it’s not under warranty due to a small accident... any help would be incredible!
  20. Dec 27, 2018 at 1:39 PM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    SAME. I've been having the issue for a while now, too. I'm a bad researcher bc I haven't found many instances of this exact problem on my truck with a solution. I'm a bit different than you two guys bc I am a 1st gen. I've checked fuses and ever tried a replacement headlight switch(based on a recommendation from someone) and neither fixed the issue. I'm curious if my dimmer relay is bad.... but that's a purely uneducated guess and I don't even know how to test the part.
