Head light problems. No high beam
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04trd, Apr 13, 2013.
  1. Sep 22, 2019 at 12:54 PM
    1998 Toyota
    1998 Toyota New Member
    Alex
    1998 Black Toyota Tacoma - 6 cyl - FWD - Automatic
    Lift Kit
    On my 98 Toyota Tacoma high beams are not working - When they are turned on, the lights go out, but the blue dash indicator does go on! With these symptoms, could someone advise what the problem is IE: switch, relay .... Looks like a real bear to replace the switch! Thanks for any help with this.
    Alex
  2. Apr 15, 2023 at 1:45 PM
    TheScirocco
    TheScirocco Member
    Peter
    Rustfree 1998 Tacoma SR5 RWD 5 speed
    K&N panel filter.
    jonesbt
    My '98 did/does the same thing after a 3" 55W 6500K HID projector swap, and I was reading that the HID swaps need a resistor wired in.
    I found this older post looking for an Ohm value, and I'm going to try 10K Ohm, to start with. That's the resistance value of the deletes I make for motorcycles...
    Btw, I tracked down 'my crank no start' condition to the BN-7 connector under the seat. The fuel pump circuit is under engineered for that connector, and it should have had a dedicated connector with better handling capability. If you haven't already, locate the connector, open it up, and look at the condition of the connector terminals. The female blue/fuel pump wire in the connector was destroying the connector housing.
