Head lights are super dim
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stum, Jan 14, 2018.
  1. Jan 14, 2018 at 7:00 PM
    Stum
    Stum [OP] New Member
    Stu
    09 tacoma
    justbought 2009 toyota tacoma super happy with truck but the headlights are cery dim is there any way to brighten up so i can c the road
  2. Jan 14, 2018 at 7:06 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
  3. Jan 14, 2018 at 7:07 PM
    Pigpen
    Dan
    Northwest Montana
    There are places that will buff out your lenses for pretty cheap. There are also kits available. Me? I'd just buy new ones. Original Toyota equipment, no cheap eBay crap.
  4. Jan 14, 2018 at 7:12 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    As you can see they were horrible, use the kit right and it will look new again. But it doesn't last unless you clear coat. Mine are already yellow again after a couple months
  5. Jan 15, 2018 at 1:25 PM
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    headlight is dim or light lens is dull? Rub out the headlight lens with some insect repellant (high deet) and newspaper and change out the bulbs to brighter ones from Autozone or any auto parts
  6. Jan 15, 2018 at 1:43 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Get this... I have used mine so many times, and it’s perfect to use on headlights with some PlastX. If the lenses are REALLY bad you may need to use some 1000 grit wet sand paper first.
  7. Jan 15, 2018 at 1:49 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Define "very dim." Are the filaments (in the bulbs) very dim or are the outer lenses so oxidized that very little light from the bulbs is actually getting out? Those are two different problems with (at least) two different solutions / fixes.
    If the actual bulbs are dim, check to see how many volts are actually making it to the bulbs. With the truck running, you should have around 14 volts. You also need to check the ground side of the circuit. A bad ground can easily cause a dim looking bulb. And if the problem is on the wiring / ground side, new bulbs are going to look just as dim.
    If the lenses on your headlight housings are oxidized, as other have already said, there are numerous kits available out there to polish them back out. If they're really bad though, you're better off replacing the entire housing. And I agree 100% that OEM housings - although more expensive - are far superior to most aftermarket housings - even the ones that look identical.
    EnonEye, crashnburn80 and PackCon like this.
  8. Jan 15, 2018 at 2:18 PM
    devkurf
    devkurf Member at Large
    midwest
    I'll second this, mine were hazed over and replaced with TYC units from Ebay or Amazon, and they scattered light everywhere. I went back to stock within a year after my truck was backed into. They aren't cheap, but we live in prime deer country, so good lights are a must.
  9. Jan 15, 2018 at 3:50 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Osram nightbreaker bulbs will help just plug and play
  10. Jan 15, 2018 at 3:57 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  11. Jan 15, 2018 at 5:22 PM
    Too Stroked
    Tom
    Not if he has a voltage / ground problem.
  12. Jan 15, 2018 at 5:55 PM
    80schild
    Chad
    Flori-Bama
    Both my Tacoma and my Tundra have some of the best headlights I have ever owned, especially those high beams.
  13. Jul 12, 2022 at 6:41 PM
    Mbiano
    Mbiano New Member
    Mitch
    96 Tacoma 2.4 5 lug
    There seems to be an issue. I just bought my 96 2.4 and the seal beams that it came with were so dim I hated driving at night. I bought the H4 replacement globes for led or halogen and I still can't see. I've removed and sanded clean the ground going from the battery to fender, did another from engine to firewall under wipers. I've replaced the plugs going to the bulbs, h4 style. With the truck not running I get over 10v pole to pole on the bulbon 1. I get over 11v on the other. I had the alternator and battery checked putting out over 14v. It seems like a ground issue but with no symptoms of a bad ground such as weak battery, flickering lights, no issues. If anyone has any input it would be appreciated. Thanks in advance.
