Head unit install/MAD
Discussion in 'Audio & Video' started by Rockoma5, Sep 1, 2019.
  1. Sep 1, 2019 at 8:10 AM
    Rockoma5
    Rockoma5 [OP] Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    Bought Pioneer 501ex from Crutchfield. Paid the extra money for the steering wheel controls and them to pre wire it up etc.
    No back up camera and no steering wheel controls work. Wasted 2 hours this morning trying to quadruple check everything with zero luck. Pissed!
  2. Sep 1, 2019 at 8:45 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Is the steering wheel control jack plugged into the correct spot? The spot will be labeled W/R on the back of the radio I believe.
    We need some more details.
    What harness did you buy? What steering wheel control module?
    Rockoma5[OP] likes this.
  3. Sep 1, 2019 at 11:15 AM
    Rockoma5
    St Louis
  4. Sep 1, 2019 at 11:38 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Here are the first steps I would look at
    -make sure the backup cam RCA is plugged into the correct camera/video input.
    -make sure the steering wheel control jack is plugged into the W/R spot
    Then
    -make sure demo mode is off
    -Make sure the camera input is on
    -make sure the camera polarity is on battery
    And see if that gets you any farther.
  5. Sep 1, 2019 at 11:51 AM
    Rockoma5
    St Louis
    is it a brown plug in for camera in top right?
    I am pretty sure I had the wr plugged in correctly though. Here is a pic of the back of the head unit.
  6. Sep 1, 2019 at 11:52 AM
    Rockoma5
    St Louis
    i had the wr plugged in but no dice
    Everything else worked.
  7. Sep 1, 2019 at 11:58 AM
    Rockoma5
    St Louis
    I also had no plug ins on the right side for amplifiers and nothing for vin vout in yellow and lin rin in white and red. I did have the antenna plugged in correctly.
  8. Sep 1, 2019 at 12:00 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah the brown rca is for backup cam.
    Double check the dip switches on the crux module just in case they overlooked them
    Based on the manual, they should be
    Down down up up down up down up
  9. Sep 1, 2019 at 12:02 PM
    Rockoma5
    St Louis
    ill check the dip switched this could be the issue there. But i have nothing to plug into the back up camera port ( i am assuming this is the problem).....I wonder if it is missing a piece or they forgot to have this wired up?
  10. Sep 1, 2019 at 12:19 PM
    Rockoma5
    St Louis
    First off thanks for the help. Secondly I see a black brown and white wire go to a connector but there is no where that plugs into back of head unit
  11. Sep 1, 2019 at 12:20 PM
    Rockoma5
    St Louis
    Here is a set of rca but I don’t know if these go anywhere also.
  12. Sep 1, 2019 at 12:28 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    The yellow is your backup cam
    RVC means reverse camera
    The red and white are connected to the aux jack down below your A/C controls
    I’m not sure about the connector with the black brown white. Just make sure that connector is plugged into the car if your car has a matching plug. The manual says some do and some dont
  13. Sep 1, 2019 at 12:35 PM
    Rockoma5
    St Louis
    Well shit. Maybe it was right and I’m dumb.... I’ll report back shortly
  14. Sep 1, 2019 at 12:35 PM
    Rockoma5
    St Louis
    Huge thanks man!!!!!!!
  15. Sep 1, 2019 at 12:36 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    The plug with the brown/ white black cables should have something to go into somewhere. I recognize that from an 8 month battle of trying to get MY reverse cam working on my aftermarket head unit. Those wires lead to the camera, at least they do in my truck.
  16. Sep 1, 2019 at 12:40 PM
    Rockoma5
    St Louis
    So the white and red plug into back of head unit that Lin Rin below my two yellow ones?
  17. Sep 1, 2019 at 12:43 PM
    ryfox0276
    Montana
    2013 RC 4x4
    I assume so? Where do those red white rca plugs go to? If it is for an AUX in (like a 3.5mm plug) that would go into the 3.5mm hole labeled AUX on the back of your new headunit
    EDIT:
    Those L in and R in plugs are for a DVD player, game console, or whatever audio signal that goes with a video input (yellow V in plug)
    Rockoma5[QUOTED][OP] likes this.
  18. Sep 1, 2019 at 1:08 PM
    Rockoma5
    St Louis
    Got back up camera. Not steering controls. Still working
    destin_meeks likes this.
  19. Sep 1, 2019 at 1:10 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Those would go here, but you need an RCA-3.5mm adapter
    HOWEVER if you’re using Bluetooth and USB, there aren’t too many times one might use the six jack on the front panel anymore. For example, I have literally never used mine, in my two and a half years owning my truck.
  20. Sep 1, 2019 at 1:16 PM
    Rockoma5
    St Louis
    Got the WR in but damn steering wheel controls no go for some reason
