Header/Exhaust wraps:
Discussion in 'Performance and Tuning' started by roxspin72, Apr 10, 2008.
  1. Apr 10, 2008 at 3:48 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Any pro's/con's...
    I have TACOROCK's cilver ceramic JBA's, just wondering if it's a bad idea or not. I know the reduce lots of heat in engine bay...
    Any input?
  2. Apr 10, 2008 at 5:07 PM
    TACOROCK
    TACOROCK Well-Known Member
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    URD SUPERCHARGER 80MM PULLEY, DOUG THORLEY LONG TUBE HEADERS, MODIFIED Y-PIPE, TRUE DUAL EXHAUST MAGNAFLOW 2 IN 2 OUT, PRO COMP 6" LIFT, WIDEBAND 02/FUEL SENSOR, AVIC D3, 2 PIONEER SUBS ON A MEMPHIS 1200 WATT AMP RMS, DIY MOD FOR ALL INTERIOR SPEAKERS FULL TINT, LEER CAMPER, EURO LIGHTS, BILLET GRILL, BULL BAR WESTIN RUNNING BARS, AIR HORN, AND A RADIATOR POPPER
    if you want to rock on!! but just know its pretty expensive and they are already silver ceramic headers.. so alot of the heat is pushed through your exhaust compared to steel or alluminu,
  3. Apr 10, 2008 at 7:16 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yeah I guess you're right. I didd'nt think it would be expensive. If thats the case I got better stuff to spend cash on...
  4. Apr 14, 2008 at 1:13 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Also the will retain a lot of mositure in the raps after you shut the engine off and the cool down something to think about
  5. Apr 22, 2008 at 9:32 PM
    Fozbo
    Fozbo Member
    Norman, OK
    03 PreRunner
    I have exhaust wrap covering my exhaust manifold and down pipe on my supra. It definitely helps with the heat, but it is a huge pain to work around when you have to (fiberglass rash is the worst) and over time it flakes and tears away. Ceramic coating will help keep a lot of the heat down like mentioned above. You might look into making some simple heat shields. On an NA vehicle, I wouldn't worry about wrapping the headers too much.
