Header Install/ Tranny Dip Stick help
Discussion in 'Technical Chat' started by cshoe98, Dec 10, 2007.
  1. Dec 10, 2007 at 7:04 PM
    cshoe98
    cshoe98 [OP] Member
    Chillicothe/Athens Ohio
    '98 SR5
    Dirt/Snow off road tires, Westin Bed X-Tender, Rain & bug guards, Nerf bars.
    Truck:
    1998 2.7L 4cyl. 4wd
    I recently found a crack in my exhaust manifold. So I plan on buying a pacesetter header for $199.00 is this a good deal?? Sounds like it comes with the gaskets and an adapter to attach it to the stock exhaust.
    What I am really wondering is this:
    I plan on doing the swap myself... and spent a little bit of time looking at the setup and it looks as if I would have to remove the transmission dipstick to allow enough room to pull the old manifold off and insert the header. How do I remove the dipstick? I was able to take off the mounting bracket that was at the top of the dipstick but still got no play with it. I noticed there was a second mounting bracket on the dipstick but would this give me enough play?
    Thanks for the help.
  2. Dec 11, 2007 at 8:51 PM
    camt10
    camt10 Well-Known Member
    03 ext cab sr5 trd 4x4
    not sure what the second mounting you are refering to but as i recall there is usally a seperating point in the middle you will notice a flange there is a o ring there that usally forms rust and gets dry and brittle soak it with some penetrating oil let it sit then slowly wiggle
  3. Dec 12, 2007 at 5:06 AM
    cshoe98
    cshoe98 [OP] Member
    '98 SR5
    Oh really? Thats cool I will have to look for that.
    But yeah if you can picture the dipstick coming out of the tranny it bolts near the exhaust pipe, then it bolts again under the air intake, at the top of the dipstick.
    But I will look for this seperation.
    Thanks.
