Header Poll: Short or Long Tube... Lets put it to a vote
Discussion in 'Performance and Tuning' started by Dakota 08, Jun 1, 2011.
Headers: Short or Long Tube??
Poll closed Jul 31, 2011.
  1. Short Tube
    11 vote(s)
    23.9%
  2. Long Tube
    35 vote(s)
    76.1%
  1. Jun 1, 2011 at 10:25 AM
    Dakota 08
    Dakota 08 [OP] Well-Known Member
    Portland
    08 Dbl Cab
    Selfishly, I'm looking into investing in headers and I want all of your advice. I'm far from an exhaust expert and only know enough to be dangerous. I'm interested in headers to restore some recently lost power from a small billy lift and slightly larger tires. I've researched that headers are a good way to regain some of that power.
    The questions are:
    What route do I go, short or long?
    Where will these different applications help give or take away power?
    Do most people go with long tubes just to avoid the welding required for instal?
    What brands/models have been well-performing products?
  2. Jun 1, 2011 at 10:33 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ^ read bold
  3. Jun 1, 2011 at 10:39 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    i agree
  4. Jun 1, 2011 at 11:53 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    The problem w/ this thread is that everyone will vote LT solely based on the fact that it is the most commonly used header. There is no solid evidence that one outperforms the other due to the lack of hard data from dyno results (mainly on STs). So, take your poll results w/ a grain of salt.
  5. Jun 1, 2011 at 12:14 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    link/repost pics please ... Im interested in seeing this
  6. Jun 1, 2011 at 12:19 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    damn that was quick
  7. Jun 1, 2011 at 12:35 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Never seen a short tube dyno posted on the 2nd gen tacoma.
  8. Jun 1, 2011 at 12:36 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Just saw the edit.
    Thats my point though. Only hearsay on the short tubes. No proof one way or another unfortunately.
  9. Jun 1, 2011 at 7:10 PM
    Dakota 08
    Portland
    08 Dbl Cab
    Damn, thats a bummer. Personally, I would rather have more power and torque on the lower end. Toyota's don't seem to want to run much above 2,000 anyway. Why would I want to go long tube if I'm going to lose low end power. Does anyone out there have any info on power gains or losses in different ends of the range with the short headers? I know you have to weld, but it just doesn't make much sense to bolt on for low end power loss.:(
  10. Jun 1, 2011 at 7:18 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    aren't you the one that bought both short and long tubes in the group buy and were going to do dyno's for both? Sorry dont want to go look thru that long thread.
  11. Jun 1, 2011 at 7:28 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I don't have headers, but it would seem illogical to slap on some long tubes simply because they're an easier install when the dyno sheets above indicate a loss of low end power. Sure they increase top end more than shorties, but I'd rather install a product (more permanently with the shorties) that doesn't have any loss over stock.... Just my 2 cents
  12. Jun 1, 2011 at 7:37 PM
    Dakota 08
    Portland
    08 Dbl Cab
    That's what I'm trying to say. A comment earlier said "then why do anything." The way I see it, if i'm going to fork over a handful of cash for a product with the intent to upgrade the power of my engine, then thats what i want. Especially when low end power increase seems more practical and more often used anyway. My 2 cents.
  13. Jun 1, 2011 at 7:43 PM
    malander
    max
    01 limited trd 4x4
    Great minds think a like brother, I say go for the shorties. I believe dt makes short tubes as well as jba maybe do some searching around for those two specific products. It wouldn't be a bad idea to message gadget at urd to get his take on things as well.
  14. Jun 2, 2011 at 5:27 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Not at all. The reason they're the most commonly run header is b/c they're easy to install (and at this point, its just regurgitation from members anyway). Most see it recommended, so others (new members) continue to recommend it, knowing its popular advice to give. Hard evidence would be proof that the LT header is the most power-producing product available for our trucks (when comparing multiple header/dyno sheets)
    Anyway, I'm not trying to knock on the LT header, I just hate seeing it be the hands down winner in a poll when it may not be the right product for the OP. If one can interpret a dyno sheet, that should at least give them some type of information as to whether or not its the right product for them. (I just wish there were more manufacturers (and designs for us)).
    Yep. have them sitting in my basement still.
  15. Jun 2, 2011 at 6:43 PM
    mnudo200827
    Michael
    Corona, CA
    whats taking so long lol, just kidding. I have the shorties and was interested in comparing the two.
  16. Jun 3, 2011 at 10:21 AM
    Dakota 08
    Portland
    08 Dbl Cab
    Would love to hear some more thoughts/opinions or maybe even a dyno test with short headers. Anybody else out there??
  17. Jun 3, 2011 at 10:26 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Dakota did you ever get my PM the other day?
  18. Jun 3, 2011 at 7:47 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    the cats have more impact on the low end (back pressure) than the headers themselves.
    On a boosted truck, I would run the LTs to help it breath WOT.
    Personally, I dont think the shorties are worth the cash/gain since the restrictive cats are still there and are not long enough for any scavenging improvement.
    I originally ran the DTLT on my X-runner since my tune with the URD MKII S/C was too hot and would melt the cats, plus the goal was 400+ rwhp ;)
    I run the DTLT on the Dcab with the TRD S/C and it breathes alot better. You will loose a little low end, but you dont notice it with the S/C and you really notice the top end gain. I think they are a tad much for an N/A truck.
    Personally, an intake, catback, and rear cat delete and some small calibrator ( MAF cal for example from URD) is the best setup for an N/A truck. Save your money on the headers.
    Again, just my opinion, take it as you wish :)
    Justin
    Justin
  19. Jun 3, 2011 at 8:39 PM
    Dakota 08
    Portland
    08 Dbl Cab
    Interesting! Help me out on some terminology (I'm a newbie to the exhaust thing). What does "S/C", "N/A", "WOT" and "MAF" stand for?
  20. Jun 3, 2011 at 8:54 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I went with Jba shorties because I didn't like the idea of having an o2 sensor faker thing. I noticed that the truck breathes a ton better now and the guy I had weld did an amazing job. The stock exhaust headers suck. They go from an oval shaped 2 1/4" piping to an almost 1 1/2" pipe going into the cat. That is some serious restriction. Now with the new stuff, it's all 2 1/4" pipe. I was going to do a before and after dyno on the truck, but I watched some utube vids of some dynos go seriously wrong. If ya got the money, do the shorts. If not the DT's will be ok with the o2 sensor tricker.
