Header problem on the 4cyl engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by cshoe98, Dec 9, 2007.
  1. Dec 9, 2007 at 9:48 AM
    cshoe98
    cshoe98 [OP] Member
    Chillicothe/Athens Ohio
    '98 SR5
    Dirt/Snow off road tires, Westin Bed X-Tender, Rain & bug guards, Nerf bars.
    So I started to notice a louder noise coming from the engine compartment...
    Immediately thought it was an exhaust leak, just did not know where. I took the air intake off then removed the heat shield around the header on the engine and noticed I have a nice size crack running clear around the header. Obviously the leak I was hearing.
    Have you guys ever experienced this problem or know of how this could happen? I have never heard of such an issue and seems like an odd spot to crack.
    Also, since I need to get a new header, is there any headers out there, aftermarket that is, that would be good to upgrade to?
    I am already expecting to dish out a large sum of money to get the header replaced so I might as well upgrade while I am at it.
  2. Dec 9, 2007 at 9:55 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    by header you mean exhaust manifold right? I have heard of them cracking on the stock manifolds...but never on the headers.... probably be easy to find a stock manifold if thats the case since alot of guys switch to header, I will once I have the cash lol
  3. Dec 9, 2007 at 5:46 PM
    cshoe98
    cshoe98 [OP] Member
    '98 SR5
    Yes you are right the exhaust manifold, my bad....
  4. Dec 9, 2007 at 6:03 PM
    cshoe98
    cshoe98 [OP] Member
    '98 SR5
    I was on the Northwestoffroad website looking around for headers to upgrade too from the stock exhaust manifold. Noticed that they do not fit the automatic 2.7L engine
    Do you guys know of any Header upgrades for a 1998 2.7L 4Cyl Automatic Xtracab?
    I appreciate it
  5. Dec 9, 2007 at 6:15 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Is it beyond repair ?
  6. Dec 9, 2007 at 6:56 PM
    cshoe98
    cshoe98 [OP] Member
    '98 SR5
    Well the manifold has got a crack running clear around it... not sure what all a repair would entail.... but I was looking to upgrade anyway to hopefully get an increase in HP/Tq and maybe even MPG.
  7. Dec 12, 2007 at 7:50 PM
    350TacoZilla
    Hancock MD
    ex GF's truck is 99 reg cab 2.7 auto truck and the pace setter header off ebay fit fine still have no clue why they say it wont fit... had to make a spacer for the tranny dip stick mount... thats all
  8. Dec 13, 2007 at 5:36 AM
    cshoe98
    cshoe98 [OP] Member
    '98 SR5
    Oh okay, well what did you make the spacer out of?
  9. Dec 16, 2007 at 12:25 PM
    350TacoZilla
    Hancock MD
    i think i just used a small piece of 3/8 fuel line cut to like 1" to space it out and longer bolt
