header question
Discussion in 'Performance and Tuning' started by Ogolimu, Aug 11, 2010.
  1. Aug 11, 2010 at 7:08 PM
    Ogolimu
    Ogolimu [OP] Member
    Banks monster and kn airfilter
    have any of u replaced ur stock headers?
    i was told id need to get 2 sensors from toyota and that would cost 400
    was thinking about long tubes from doug thor and urd ypipe and a banks cat back and kn cold air in already
    but the shop that did the install said id need those sensors if i did the headers
  2. Aug 11, 2010 at 7:09 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    you dont need new sensors just reuse the old ones. unless they are bad and throwing codes
  3. Aug 11, 2010 at 7:11 PM
    Ogolimu
    Ogolimu [OP] Member
    they told me the way toy puts it in most of the time u break one or both
    does the urd sensor thing replace those?
  4. Aug 11, 2010 at 7:12 PM
    08pretaco
    az
    im guessing you have a v6 and which sensor are you referring to? post a link up
    are you talking short tube long tube?
  5. Aug 11, 2010 at 7:15 PM
    Ogolimu
    Ogolimu [OP] Member
  6. Aug 11, 2010 at 7:16 PM
    08pretaco
    az
    ok nvm your looking long tube since you mentioned the o2 sensor. ya the 02 sensor does something but it does not replace the factory sensors. it work with them to "fool" the computer
  7. Aug 11, 2010 at 7:16 PM
    Ogolimu
    Ogolimu [OP] Member
    ahh ok
    so i may have to replace the real o2 sensor?
  8. Aug 11, 2010 at 7:17 PM
    08pretaco
    az
    if you go to a shop they will say anything and everything to sell you more than you really need. I am sure that there are a few write ups here on the forum for the install and I think they reused the stock sensors. Personally its a little time consuming but if you could install the headers yourself that would be the way to go...just make sure you get all new gaskets for a leak free exhaust
  9. Aug 11, 2010 at 7:20 PM
    08pretaco
    az
  10. Aug 11, 2010 at 7:22 PM
    Ogolimu
    Ogolimu [OP] Member
    dont even know if i could probly dont have the tools to do it
  11. Aug 11, 2010 at 7:25 PM
    08pretaco
    az
    tools..do you have a basic socket set? I am pretty sure thats all you need. I have a 2.7 and did the header install and my tool box is a 24 socket wrench set, it had everything I needed.
  12. Aug 11, 2010 at 7:29 PM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    And patience. Can't be near as hard as LS1 headers. Takes forever, like a jigsaw puzzle.
    If you have not done this before find someone that has some mechnical know how to help. You will save a ton of money. But, I suggest to read and study your arse off first before you get started so you know all the pieces that are in play here.
  13. Aug 11, 2010 at 7:32 PM
    Ogolimu
    Ogolimu [OP] Member
    hmm from reading that 2 links idk about doing it now cause the sound would be loud and raspy
  14. Aug 11, 2010 at 7:41 PM
    08pretaco
    az
    then PM the members from those links and ask them what muffler/resonators they are using because that will illiminate alot of the rasp
  15. Aug 11, 2010 at 7:43 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    you don't have to replace anything.... you are doing a direct swap.... you will need a o2 simulator that urd sells for a special price with a purchase of headers. give gadget a call and he will get you set up. the sound is perfect in my opinion. :) good luck with your purchase.
  16. Aug 11, 2010 at 7:43 PM
    08pretaco
    az
    ^ there ya go straight from the...damn ramon! thats a sick runner!
