Headlight advice needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deadbolt, Sep 27, 2008.
  1. Sep 27, 2008 at 2:56 PM
    deadbolt
    deadbolt [OP] do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
  2. Sep 27, 2008 at 2:58 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Looks like you will only have low beams if you get them.
  3. Sep 27, 2008 at 3:00 PM
    jolayiv
    Jim
    New Bern NC
    I think you should do the BHLM yourself and spend your money on a good quality set of HID's and retain your Hi/Low beams.
  4. Sep 27, 2008 at 3:11 PM
    deadbolt
    Socal
    I'm a bit scared to do the BHLM myself. Not too familiar with doing that. And if something happens, I wont be able to drive my truck until i get new headlights.
  5. Sep 27, 2008 at 3:18 PM
    jolayiv
    Jim
    New Bern NC
    True. If you read up on it there have been a lot of trial and error jobs so you should be able to do it w/o any problems. PM some of the guys that have done it.
  6. Sep 27, 2008 at 3:20 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    I guess I'm a bit out of the loop. What's the difference between HID's and regular head lights? It looks like HID's aren't really a bulb at all.
  7. Sep 27, 2008 at 3:26 PM
    jolayiv
    Jim
    New Bern NC
    Take a look at this http://www.halcyon.net/lights/hid-faq.shtml It's better than me trying to explain it.
  8. Sep 27, 2008 at 3:36 PM
    Taco's for All
    Lake George, NY
  9. Sep 27, 2008 at 3:40 PM
    jolayiv
    Jim
    New Bern NC
    You can rep me later :rolleyes:
  10. Sep 27, 2008 at 8:41 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I buy a pair of Bi-Xenon HID ...it have high, low beam. it cost me about 230.00.. I have a 6000K, and I get a set of 3000K Yellow for the fog light... it is bright like the sun.
  11. Sep 28, 2008 at 2:53 PM
    deadbolt
    Socal
    Anyone else have any suggestions?
  12. Sep 28, 2008 at 2:56 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Talk to beastbluetaco at toyotanation see what he can do for you he will most like send you his that he has done and you send him yours when you recieve his.
  13. Sep 28, 2008 at 3:00 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Id suggest this too. Or if your nervous to do this (as am i) maybe you can go down to the dealer buy an extra set of lights and then try the BHLM on the ones of your truck and if something goes wrong then swap them with the new ones you bought? Might be expensive but its a thought
  14. Sep 28, 2008 at 3:02 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
  15. Sep 29, 2008 at 10:09 PM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    If you decide to do the Black HL mod, it's not that bad. Once you remove the housings from the truck, just follow the instructions posted online, removing all the rubber grommets and plugs.
    If you take your time and make sure to pull them apart slowly, you will be fine. The most important step is when you put them back together. Make sure you get them warm and the sealant is soft. If you need to add sealant after you put them together, make sure you go all the way around the housings with clear sealant.
    For HIDs, I highly suggest the RETRO SOLUTIONS kit. I used the bi-xenon 55W kit which gives high/low beams and they turn off/on just like factory headlights, nothing to modify other than a straight forward installation.
    Great upgrade, OEM look, easy installation, plug and play.
