headlight aiming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fibertop, Oct 18, 2009.
  1. Oct 18, 2009 at 8:29 AM
    fibertop
    fibertop [OP] Well-Known Member
    roger
    Ontario, Wasaga beach
    2010 sport DC
    Does anyone have a tutorial on headlight aiming? I recently lifted the front of my truck by 3 inches. Now i'm getting headlight flashes. I will soon be adding xenon lights to the brew and I would like to compensate for the lift. Is this something a layperson can do or should I take it to a dealer?
  2. Oct 18, 2009 at 8:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Oct 18, 2009 at 8:46 AM
    fibertop
    roger
    2010 sport DC
    Thanks. This is way to much work for me. I will have to pay a dealer I guess
  4. Oct 18, 2009 at 8:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its really easy. Do you have anyone near by that can help? Where do you live?
  5. Oct 18, 2009 at 8:53 AM
    fibertop
    roger
    2010 sport DC
    a few miles from AZ. I'm in Ontario Canada. Maybe I will give it a try.
    Thanks
    Roger
  6. Oct 18, 2009 at 8:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you have a long screw driver, use that. Aim the truck at a flat block wall, and move the light down a little bit. If your 10 feet or so from the wall, aim down about 3 to 6". AK27 is near you, I think...He could probably help. :)
  7. Oct 18, 2009 at 9:01 AM
    fibertop
    roger
    2010 sport DC
    Thanks, that sounds more my speed.
    What I love about this forum is that there are so many of us on it that you get instant replies.
  8. Oct 18, 2009 at 9:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In the link I sent, It shows which adjuster moves the light down. Just make sure you use the correct adjuster for each light, and you can do it your self, if you have a long phillips head screw driver.
  9. Oct 18, 2009 at 9:39 AM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    Take it easy. There's a post out there claiming the gearing on the screw is low, requiring a lot of turns to adjust. Not true!!
    For my lift, which is 3" rear 2 1/2" front, I think I ended up with about 3-4 turns clockwise. (After reading the "low gear" post, I started with ~20 turns!!) Take your long #2 Phillips screwdriver, and a flashlight (do this at night). Give the screw 2-3 turns on both lights (adjust them evenly) and go for a short drive. Continue adjusting until you're happy with the light and no-one flashes you. Keep track of how many turns you've made so you know how much adjustment you need on each pass. Done! Also, with every adjustment check your brights. Need to get the balance between good low beam visibility and keeping the brights usable. Realistically, if your lows are too high to make the highs usable, you'll get flashed by oncoming drivers!
  10. Oct 18, 2009 at 11:48 AM
    fibertop
    roger
    2010 sport DC
    The link says that turning the screw counterclockwise moves the beam down. Your post says you ended up turning it clockwise. Were you adjusting your beam up?
  11. Oct 18, 2009 at 11:49 AM
    AK27
    AK27 Well-Known Member
    hey roger, if you need a hand let me know!
  12. Oct 18, 2009 at 11:52 AM
    fibertop
    roger
    2010 sport DC
    Thanks AK. I see the screw and I should be able to handle this. Where are you located? Are you the guy in the beach?
  13. Oct 18, 2009 at 11:53 AM
    AK27
    nope, i'm in barrie. not to far away :)
    meaford mike is not to far from ya
  14. Oct 18, 2009 at 12:03 PM
    Black Rock Taco
    2011 DBL Cab Tundra
    None, yet
    My lift raised the rear a good 1/2+ inch higher than the front, so yes I needed to RAISE the headlight aiming point. If you're leveling, you'll need to lower the aim. Each lift result is different!! Remember to keep the left light a bit lower than the right- that's how all vehicles come aimed stock. Helps keep oncoming traffic happy. Right side a bit higher won't blind oncoming traffic, allows better side visibility and makes signs a bit easier to see.
    Keep the screwdriver in the truck, and you can re-aim on the fly if you're temporarily carrying a load, dirt bike or ATV....just keep track of the turns so you can return to original setting!!
  15. Oct 18, 2009 at 12:13 PM
    fibertop
    roger
    2010 sport DC
    Interesting about the left being lowered more than the right. My son's hummer is like that which we noticed after converting to xenons. Now I know why, thanks
  16. Oct 18, 2009 at 1:13 PM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    Just let me know if you need any help, I'm in the GTA if that helps.
  17. Oct 18, 2009 at 1:19 PM
    fibertop
    roger
    2010 sport DC
    Thanks to all for the help!!!:canada:
  18. Oct 18, 2009 at 1:50 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    If I can help I will, have not done this yet but maybe should since I tow a heavy trailer, and get flashed all the time.
  19. Oct 18, 2009 at 6:21 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I've been putting this off for WAY too long... subscribing for an easy find later on... :D
  20. Jan 10, 2010 at 10:12 PM
    b168
    b168 Well-Known Member
    South Bay, CA
    09 Tacoma DC TRD Off Road
    6" Pro Comp Lift 35" Xtreme A/T Pro Comp Tires 4.56 Gears
    how does the left and right aiming works whne u turn the screw?
    is it when turned clockwise does it go right?
    thanks for the help
