Headlight Blackout 2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by midlife4X4fix, Sep 10, 2012.
  1. Sep 10, 2012 at 8:33 AM
    midlife4X4fix
    midlife4X4fix [OP] Well-Known Member
    Berkeley, Ca.
    12 Tacoma XC 4X4 stick
    1-1/2" Lift, Larger Tires, Headache Rack, Tool Box in Bed, Tailgate retainer clamp and cable, Grillecraft grille, RECARO Seats, Re-upholstered interior with matching RECARO fabric, painted all chrome areas and debadged entire Truck, BAMF sliders, Blacked out headlight inner frames and misc interior trim panels, Removed XM Fin, Removed front and rear bumpers. Rigid SR 20" LED Light bar, Pelfreybuilt Front Plate Bumper Ordered. Looking at Rear Plate Bumpers now.
    I followed the oven heating instructions(8 minutes at 200 degrees) and had an easy time removing my inner headlight frames in order to scuff them down and paint them flat black.
    Also removed my front bumper in anticipation of arrival of my Pelfreybuilt plate bumper:D
  2. Sep 10, 2012 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Very nice!
  3. Sep 10, 2012 at 9:48 AM
    jdm.obp
    jdm.obp Well-Known Member
    561, FL
    3" Pro Comp, 5% all around, Antenna X shorty, Debadged
    looks good man. Doing that to mine at the end of the month hopefully. What did you use as a resealer?
  4. Sep 11, 2012 at 12:38 AM
    D44boy
    D44boy Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    that looks good!
  5. Sep 11, 2012 at 1:29 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    The new '12 style headlights look awesome with the BHLM! :bananadance:
  6. Sep 11, 2012 at 5:36 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    Lookin good...I need to get on that...
  7. Sep 11, 2012 at 8:15 AM
    midlife4X4fix
    Berkeley, Ca.
    I just re-heated and put them back together. It looked like there was plenty of the stock sealer still there. Plus the headlight really isn't "sealed" due to the 3 bulb penetrations at the back..
  8. Sep 12, 2012 at 8:13 AM
    midlife4X4fix
    Berkeley, Ca.
    I will likely take them apart when I can get a Bi-Xenon Retrofit kit to go in there.
  9. Mar 6, 2013 at 9:15 AM
    Liem Salim
    Liem Salim Active Member
    Bremerton, WA
    2013 Tacoma TRD Sport
    K&N Cold Air Intake (63-Series) Retrofitted Headlights (FX-R Stage III w/ Apollo 3.0 shroud) Leer 180 Cap Custom Bed Sliders iPad Mini Entertainment System LED bed lights
    what temperature did you use when baking the head light in the oven and did you set the headlight on anything in the oven or did you just set it on the rack it self? Also to you have a tut. for blacking out the lights?
  10. Mar 6, 2013 at 9:37 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    There is a whole write-up on this if you search the forum, but it states in this thread (8min at 200) also, you will put a piece of cardboard in the oven to sit them on.
    Here is a great write up. http://www.tacomaworld.com/forum/lighting/65226-how-black-head-light-mod.html
  11. Mar 6, 2013 at 9:48 AM
    Liem Salim
    Bremerton, WA
    Thanks thinking of retrofitting my light and it would just be damn good blacked out.
  12. Mar 6, 2013 at 9:57 AM
    aubi1414
    Justin
    Pensacola, FL
    DO IT!! :D
