Headlight gone out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, May 2, 2011.
  1. May 2, 2011 at 7:27 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    Off Road
    Leer Cap Kenwood DNX 9140 Boyo back up cam HD Raido Sirius Weather Tech Mats Memphis Audio, Valentine One radar,Tinted windows,Wet Okole's, Bed mat.
    I have an 09 and I was having intermittent problems with my right headlight going out. So I would touch the socket and get it come back on.. It happend several times where I had to do that. Now it wont come back on at all. Guess I should pull the bulb and see if its burned out.
    Wondering what the deal might say about this.
  2. May 2, 2011 at 7:29 AM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    I would check the plug itself and make sure none of the wires aren't loose or coming out before you pull the headlight.
  3. May 2, 2011 at 7:29 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    should be still under warranty? just take it in and see what they say is what i'd do
  4. May 2, 2011 at 7:56 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Try checking the pins on headlight socket.
  5. May 2, 2011 at 7:59 AM
    boxxed
    Denver, CO
    Off Road
    OK I will try a few of the suggestions.. I have just been pretty busy and finally had time to write a quick post...
    so thanks for the replys.. it gives me some direction..
  6. May 2, 2011 at 8:00 AM
    boxxed
    Denver, CO
    Off Road
    I like that flat black grill.. What did you do to prep the chrome plastic?
  7. May 2, 2011 at 8:01 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Sounds like a loose socket or a bad bulb. This should take less time to fix then going to a dealership...since my dealership is 50 miles one way.
  8. May 2, 2011 at 8:08 AM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    I actually found a basic black plastic oem grill and used a plastic primer and flat black rattle. I have a chrome satoshi and a normal chrome grill sitting in the garage as well.
    The normal chrome grill is being stripped of the chrome (a PITA i tell you) and will be turned into a black satoshi this summer.
  9. May 2, 2011 at 10:04 AM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    A new bulb is a 30 second fix. Just did one last week.
  10. May 9, 2011 at 8:27 AM
    boxxed
    Denver, CO
    Off Road
    Yepp, you are correct. It was..
    Thanks TW.
