Headlight Haze
Discussion in 'Detailing' started by bowzerdoo77, May 27, 2008.
  1. May 27, 2008 at 10:23 AM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    does anyone know how to remove that haze on the headlights? I can get it to go away for about an hour then after it dries its back.. :eek:
  2. May 27, 2008 at 11:11 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    depending on what your detailing supplies include, if you hit them with a mild polish and a random orbital, it will clean them up.
  3. May 27, 2008 at 12:48 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hey 77 did you try that stuff?
  4. May 27, 2008 at 6:22 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I got the stuff but ended up at hooters and now its dark ill try it tomorow
  5. Jun 1, 2008 at 1:39 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    I actually sanded on one of my headlamps to remove 18K miles of road wear specks. I wet sanded for 2 hours on that thing with (4) different grits. After I was done that headlamp assy. was very white colored and opaque. I tried hand polishing it but that failed to remove anything. Went and got a mini power Ball made by Mother's. Used Flitz metal polish and an hour later the lamp assy was all clear again.
    If you just have haze and are not interested in getting the specks off, just use some of that restore type lens polish or Flitz and one of those power balls and I guarantee you will be amazed at how good it looks.
    If you ever sand one of these type housings: use more strokes, not more pressure. A constant stream of water to carry away the grit and residue is desired.
    This is the lamp assy. that was all white and opaque from sanding. It turned out rather nice.
    EDIT: I would pour some polish onto the lamp and then used the Power ball running slow to get it spread all over the lamp assy. Then start on medium speed and start going from one side to another, top to bottom over and over until the polish is almost dried up and gone and soaked into the power ball. Then right before all of it is soaked up go to high speed and polish in the same method as described above. Left to right then drop down a bit and right to left, etc. The results were amazing. when done wash nad clean that lamp aasy. well and then hit it with a good WinDex cleaning. After that dries well, hit it with some sort of plastic wax. I just used my normal NXT Generation Tech Wax to coat the one in the pix. :)
  6. Jun 6, 2008 at 10:00 AM
    TheOriginalTXTACO
    TheOriginalTXTACO Active Member
    San Antonio, TX
    Unfortunately No More
    3" lift, Extreme LineX, Extang Toolbox Tonnoe, UWS Box, MB Wheels, BFG AT's.
    Meguires PlastX works well with an orbital and a sponge type applicator, it keeps my lens covers pretty clear after 107k mi.
  7. Jun 6, 2008 at 12:47 PM
    wbhvacer
    wbhvacer Well-Known Member
    Cartersville Ga.
    Dodge Challenger Rt
  8. Jun 6, 2008 at 6:54 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    GS-27 GS-27 GS-27 puts your headlights in HEAVEN you will be amazed that they will no longer be hazed if you try it one time...with me you will chime ""YAAAAAAY GS-27"" :bananadance::bananadance:
  9. Jun 7, 2008 at 8:03 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have a couple of tubes of gs-27....really good for light scratches and such. im gonna try it on my wifes accord headlights, with my powerball mini. they are getting a haze on them, so ima let ya know how the gs-27 does on it. the meguiars plast-x didnt do alot to them, but then again, i did it just by hand, not with the powerball.
  10. Jun 7, 2008 at 10:39 AM
    TheOriginalTXTACO
    San Antonio, TX
    I assume the GS27 is sold at my local auto parts store.
  11. Jun 7, 2008 at 10:41 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it may be.........i know i have seen it at autozone and oreilly's before.
  12. Jun 7, 2008 at 2:26 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Hey T-lemme know:)........howdja like my lil jingle:D
  13. Jun 7, 2008 at 2:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    awesome sales pitch bro:D!!!
  14. Jun 11, 2008 at 6:09 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    So nobody tried the GS-27 on their lights??? Im not sellin the stuff-it works!
  15. Jan 28, 2012 at 4:59 PM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    I used Rainx headlight restorer kit today with excellent results. I highly recommend for those on a budget who want the light penetration that they had when they first got their truck.
  16. Feb 7, 2012 at 8:44 PM
    htuong95
    htuong95 Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    Try toothpaste. Spray with water first then buff with toothpaste. It works. There are couple of videos on YouTube.
