Headlight & HID Fog's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Corndawg, Jun 3, 2012.
  1. Jun 3, 2012 at 8:04 AM
    Corndawg
    Corndawg [OP] Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
  2. Jun 3, 2012 at 8:07 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    link doesnt work
  3. Jun 3, 2012 at 8:20 AM
    Corndawg
    Corey
    Utah
    allright i fixed it ^^
  4. Jun 3, 2012 at 8:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lots of people running them and most have said the lighting is worse than stock but not bad if you like the look. I would run a bead of silicone around where the lens meets the housing to prevent any leaking. Some of the aftermarket housings have been known to leak if they're not sealed up when they are new.
  5. Jun 3, 2012 at 8:24 AM
    Corndawg
    Corey
    Utah
    guess ill have to get some hid conversion kit
  6. Jun 3, 2012 at 8:41 AM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    There's someone selling a badass retro in the forsale section.
  7. Jun 3, 2012 at 4:24 PM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    I have a set on my truck. The light output is kind of dim compared to the stock lights. I did have both lights leak, I resealed them and they were fine for a while but one started leaking again I think I missed a spot when I sealed them. Overall I like the looks and I think with a good aftermarket bulb the light output would be better. If you get them seal them real good around the outside. I would toss the bulbs they come with and get some good ones.
  8. Jun 3, 2012 at 5:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    As a 100% rule, eBay projectors suck.
    With Halogens, they suck.
    With plug-in HID retrofits, they splatter and blind other drivers, and for you, aren't any better than stock.
    If you want HID, go with a proper true projector retrofit. Once the stock housings are opened up, you can paint the inside (since the reflector won't be used anymore), add LED strips, etc....
  9. Jun 4, 2012 at 4:27 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    You and Rich have to quit dropping all that common sense around this place.
  10. Jun 4, 2012 at 4:45 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Damn, almost made it a week without one of these threads, gotta be a record.
  11. Jun 4, 2012 at 6:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Hey, what's the biggest tire I can put on my 5-lug?
    I don't have a lot of money so I need to use the stock 15" rimz too... can I add a rubber strip and use 18" tirez so I don't have to buy a new set when I get new rimz?
