headlight problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Mar 15, 2009.
  1. Mar 15, 2009 at 9:09 AM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    my truck one night just decided to not let my use the low beam feature. WEIRD. it was both bulbs at the same time. i checked the fuses before i realized the brights still worked. but when i turn the brights on, and the bright indicator on the dash does not come on.
    so what the hell is going on. i don't have a lot of cash to drop right now. becau:confusedse I'm traveling left and right.
    this next weekend. St louis supercross. the weekend of the 28 im in Phoenix
    :goingcrazy:
  2. Mar 15, 2009 at 9:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any chance it could be that the high beams burned out?
  3. Mar 15, 2009 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you have a multi meter, check to see if power is going to the high beam wires.
  4. Mar 15, 2009 at 9:14 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    If your headlights still work, I dont see much of a problem. When they dont work consistently, I would try to find the problem.
  5. Mar 15, 2009 at 9:15 AM
    Hambone155
    omaha
    the highs work the lows don't.
  6. Mar 15, 2009 at 9:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....Sorry. Check the low beam wires. Low beams could just be burned out.
  7. Mar 15, 2009 at 9:19 AM
    dually
    dually Low and slow
    Yeh, just pull the bulb out of the headlight and take a look.
  8. Mar 15, 2009 at 9:21 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I had both low beams burn out at the same time on my 4 runner, thought it was something else cause I just couldn't believe both would go at the exact same time.
    Luckily I had one spare bulb in the garage and as soon as I plugged it in that solved the problem so grabbed another one on the way to work
  9. Mar 15, 2009 at 9:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think his year has sealed beams.....Needs to replace the whole light.
  10. Mar 15, 2009 at 9:25 AM
    Hambone155
    omaha
    nice chris yeah there an assembly
  11. Mar 15, 2009 at 9:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, still not hard to replace. Test the low beam wires first to make sure they are getting power. That will let you know if it could be a bulb.
  12. Mar 15, 2009 at 9:28 AM
    Hambone155
    omaha
    yeah thats what i thought i was going to do but thanks all
    thanks again.
  13. Mar 15, 2009 at 11:28 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Hi, did you use any high output lightbulb? like 100W low beam something like that?
    if do, there will be a chance your wire harness burn out at the socket connection, check it.
    Hope this help.
  14. Mar 15, 2009 at 1:29 PM
    dually
    dually Low and slow
    ^Its a sealed beam.
  15. Mar 15, 2009 at 3:09 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i had the same problem.both low beams crapped at the same time.turned out to be those crappy super white bulbs from autozone. put the stock ones back in and good as new.
