headlight reminder beeper?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joels98taco, Jun 15, 2012.
  1. Jun 15, 2012 at 10:09 PM
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    ok guys so am i crazy or do the 1st gens come with a beeper to remind you if you leave your lights on? i remember mine had it but it doesnt work anymore. how do i fix it?? i hate when i go camping/hunting and drive in the morning i always forget to turn them off when the sun comes up and the battery dies lol. any help would be appreciated :eek:
  2. Jun 15, 2012 at 10:12 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Huh? In my '01 DCSB the lights will turn off automatically when I open the doors if they are left on.
  3. Jun 15, 2012 at 10:18 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i thing pre 01s have a beeper but not sure ill see what others have to say
  4. Jun 15, 2012 at 10:21 PM
    Madjik_Man
    Colorado Front Range
    My 98 has a constant chime reminder.
  5. Jun 15, 2012 at 10:28 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    ok cool any idea where it is or how to fix it??
  6. Jun 16, 2012 at 6:16 AM
    Madjik_Man
    Sorry, I do not
  7. Jun 16, 2012 at 11:27 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    It will take a bit of troubleshooting. I might be able to help. I have a basic model SR5 without electric locks or windows, or tach, etc. My headlight/tail-light reminder does work, however. It emits a constant tone when I open the door. The buzzer sounds like its under the dash near the drivers left knee.
    The ignition key reminder seems use the same buzzer. If I leave the key in the ignition, and open the door, the buzzer goes off (pulsing, not constant). I think the "integration relay" controls the sound made by the buzzer, depending on the situation detected.
    Does your ignition key reminder work?
  8. Jun 16, 2012 at 2:03 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    You could always buy a buzzer from radio shack and put it in where the parking light fuse is. I did that for an old toyota pickup I had.
  9. Jun 16, 2012 at 2:45 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Shit to tell you the truth I don't think either works but ill check when I get home. Toyota probably sells that little buzzer right?
  10. Jun 16, 2012 at 4:10 PM
    tan4x4
    Rick
    Folsom, CA
    I couldn't find the buzzer in the wiring diagrams, it may be included in the 'integrated relay'. Likely a pricey item.
    If both the ignition and headlight minder are not working, then it might just be a fuse. My FSM lists a blown dome-light fuse under the hood, as a possible cause.
    The dome-light also is connected to the door switch. If all three are not working properly, then it could be that door switch, near the drivers left shin.
