Headlight Replacements
Discussion in 'Lighting' started by JTyfz450, Dec 3, 2015.
  1. Dec 3, 2015 at 12:51 AM
    JTyfz450
    JTyfz450 [OP] Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
    I have a 2012 Tacoma and about a 2 years ago the headlights started to yellow. I got them cleaned up, but they are yellowing again. Just seems like this is going to be happening over and over again.
    My best option at this point is to just replace them. I'd definitely go OEM on them, but if there are great quality aftermarket replacements for a lower price please let me know. Tried looking for some aftermarket replacements, but the same issues kept coming up (fogging up, melting, yellowing, etc etc).
    Thanks in advance!
  2. Dec 3, 2015 at 6:07 PM
    JTyfz450
    Jeryck
    SoCal
  3. Dec 3, 2015 at 6:20 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is very early for your lenses degrade. Are you running HIDs? If not, clean them up again and apply headlight uv protectant. When you polish up the headlight, you remove the UV stabilizer, so they will degrade much quicker. Applying a stabilizer every 6 months solves the issue.
    http://www.amazon.com/gp/aw/d/B006F...Protectant&dpPl=1&dpID=417ZeBKMixL&ref=plSrch
    If going OEM you may upgrade to the Pro lights, see the headlight upgrade link in my sig.
    If going aftermarket, I would only get CAPA certified lenses, anything else doesn't need to meet the same quality optics, and can be a significant downgrade. I've purchased non-CAPA lights and the beam pattern was so bad they ended up in the trash.
  4. Dec 3, 2015 at 6:28 PM
    JTyfz450
    Jeryck
    SoCal
    Thank for the info! I was running LEDs at the time. Didn't think they would get hot enough to degrade the lenses.
  5. Dec 3, 2015 at 6:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LEDs shouldn't get hot enough to be an issue. HIDs put out UV which degrade lenses if the UV bulb filter is poor quality, LEDs do not.
