Headlight Revolution S-V.4 LED Review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RedWings44, Nov 22, 2020.
  1. Nov 24, 2020 at 11:34 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    sure didnt look like a downgrade. Pictures look alot clearer.
  2. Nov 24, 2020 at 11:35 AM
    auskip07
    Skip
    Atlanta, Ga
    why not just adjust the lights down?
    Xx_Evilvirus_xX likes this.
  3. Nov 24, 2020 at 12:41 PM
    pandonsf
    pandonsf Well-Known Member
    Brandon
    Millbrae, CA
    2019 Tacoma TRD Off-Road
    probably could have/should do that anyways. maybe i'll give it a shot. always hated adjusting headlights
    RedWings44[OP] likes this.
  4. Nov 24, 2020 at 1:37 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    The low beams have less throw.
    The high beams look brighter, but what good is that in a populated area.
  5. Nov 24, 2020 at 3:02 PM
    auskip07
    Skip
    Atlanta, Ga
    if you count the dividing lines on the driver side of each picture they look very comparable concerning throw and better with the immediate area.
  6. Nov 24, 2020 at 3:46 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    needs picture of cutoff line taken with a manual exposure camera on the same settings.
    They certainly look brighter on the pavement, but that is mostly useless light. How's the beam pattern on a vertical surface the same distance from the vehicle between the two. Not getting flashed doesn't mean much these days, there are tons of idiots driving around with LED drop in bulbs, it's becoming a regular night time commute thing to see several. The displacement of the diodes from the center plane of the bulb assembly looks to be on the worse side of most.
    Supa White Taco likes this.
  7. Nov 24, 2020 at 6:22 PM
    RedWings44
    RedWings44 [OP] Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Debatable about the downgrade. But as I said, this is a comparison to stock. I have not done any sort of H9 conversion nor put any different halogens in there.
  8. Nov 24, 2020 at 6:22 PM
    RedWings44
    Michigan
    You should adjust them after a lift anyway
    pandonsf[QUOTED] likes this.
  9. Nov 24, 2020 at 6:23 PM
    RedWings44
    Michigan
    They seem to have the same throw, especially in these projectors
  10. Nov 24, 2020 at 6:29 PM
    RedWings44
    Michigan
    I agree. However, I haven't been able to get a good photo for reference because of the crap piled up in my garage and the fact that the wall is bare OSB. The outside isn't much better due to the light pollution from the parking lot. That's the the only reason I didn't include a side by side shot. However, I assure you they are the exact same cutoff. I measure this by physically marking the location of the cutoff point from approximately 20' on the OSB and then comparing after install. Not to mention the real world driving.
    Sure, not getting flashed doesn't mean much. But not getting flashed after 5 months and well over 10,000 miles means a little more. I also touched on the diode sizing in the review. The difference is negligible from a driving standpoint, but measurable on the light itself. But, as I stated, if my measurement holds true, it is thinner than the thinnest LED bulb tested to date in the megathread.
    Irons likes this.
  11. Nov 28, 2020 at 7:14 PM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
  12. Dec 9, 2020 at 8:03 AM
    dave82at
    dave82at Well-Known Member
    David
    Ontario/Canada
    2020 TRD Sport
    Tuned
    @mds08 I installed my SL1s. Did you have to adjust the collar on any of your bulbs to line them up properly as per the instructions?
  13. Dec 26, 2020 at 1:10 AM
    RedWings44
    Michigan
    You evidently did not read my review, then. The entire reason I made this was because they had NOT been tested in the mega thread. I also made a few comments about HR in the post.
  14. Dec 26, 2020 at 1:11 AM
    RedWings44
    Michigan
    I have no direct comparison, however, my measurement of the width showed them to be closer to stock than the Hikari bulbs. But, that being said, take my measurement with a grain of salt.
  15. Dec 26, 2020 at 6:50 AM
    #35
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Mine went in and were just fine. No adjustments made. I made this drive every Christmas day to some family who lives in the county. We normally drive my wife's 4runner but I wanted to put my SL1s to the test on these country roads which are pitch ass dark, even more so than where I live. I drove out there with the SL1s and they were perfect, could see great distance and the side of the roads were nicely lite. I had some time and for the heck of it put in my GE mega 130s and drove around some. Absolutely no comparison at all. My LEDs went back in. My SL1s weres clearly a better performing light all around. The difference was extremely noticeable! Even Ray Charles would be able to see the difference.
  16. Dec 26, 2020 at 6:52 AM
    #36
    RedWings44
    Michigan
    Actually, thats exactly what they are designed for and the technology is constantly evolving. Definitely not perfect, but if you actually read my review, you'd see my thought process behind this particular light. But, to each their own. Thank you for your input.
    VaToy likes this.
  17. Dec 26, 2020 at 7:40 AM
    #37
    VaToy
    Parts Unknown
    Agreed!!!!
  18. Dec 26, 2020 at 9:49 AM
    #38
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I have them and think they are awesome. I gauged them by how much I could see when off roading at night. Massive improvement over stock. However, when I first put them in I was getting flashed constantly (have a 3" lift). Had to adjust them down which does reduce the low beam effectiveness a bit.
    With high beams on, they work so well that I may not have bought the Ridgid Industries grill + light if I had gotten the SVs sooner. Would have saved me a grand.
  19. Dec 26, 2020 at 1:32 PM
    #39
    RedWings44
    Michigan
    Well, I'm not going to sit here and argue with you. Like I said, to each their own. This is my view and thought process behind it.
    VaToy likes this.
  20. Dec 26, 2020 at 1:50 PM
    #40
    VaToy
    Parts Unknown
    People see things in their own right mind as they want to see it, some want to be a know it all and the hell with what you think or your first hand knowledge. I too agree completely with you, as companies change and improve things. Like computers they change daily,so to sit here and listen to someone on the forums tell you your wrong is a complete waste of your time. I run the LEDs in my stock OEM housings and I couldn't be happier. In fact I can see further, and have a wider throw of light, it looks better and I'm totally sold and loving them. So for someone to tell me I'm wrong would just be like, right okay, and move on. Their opinion is of no value when seeing is believing.
    Irons and RedWings44[QUOTED][OP] like this.
