Headlight upgrade harness, upgraded bulbs or brightboxes?
Discussion in 'Lighting' started by iroc409, Oct 3, 2009.
  1. Oct 3, 2009 at 12:44 PM
    iroc409
    iroc409 [OP] Well-Known Member
    Washington
    A red one
    I have read a lot of people using an upgraded wiring harness and it makes a big difference with even stock headlight bulb output. Has anyone tried this on a 2nd gen Tacoma, and was it worth it?
    Also, has anyone tried a “brightbox” mod or tried the 55/100W bulbs? Will the 100W high beams melt the headlights (obviously these can only be used with upgraded light harnesses)?
  2. Oct 3, 2009 at 3:23 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Are you talking about HIDs?
  3. Oct 3, 2009 at 4:10 PM
    iroc409
    Washington
    A red one
    No, this is for standard halogens. I have a set of bixenon HIDs, but I have not installed them yet. I am concerned about the glare, and have been considering just converting my driving lights to HID instead. I would like to have a little more oomph out of the low beams if possible, and just seeing what the options may be if anyone has messed with it.
    I go on a lot of camping and road trips when I can and we end up on a lot of empty dark highways and winding back roads. Lighting, brakes, and tires are my top priorities. We have a long winter road trip coming up soon as well.
  4. Oct 3, 2009 at 8:51 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    :confused:
  5. Oct 3, 2009 at 8:53 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Never heard of upgrading your harness for stock bulbs. Don't see how that would make a difference. And obviously, as you said, you can't upgrade to a higher wattage bulb without a new wiring harness because you'll burn up the stock wiring.
  6. Oct 3, 2009 at 8:54 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    if your gonna mess with your headlights, might as well go for the Halo HID kits
  7. Oct 3, 2009 at 8:57 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    Back when I was wrenching on honda's you should run the power wire directly to the battery and use the stock 12v power to hit a relay. That way you got something like 14v at the light connector and it made the lights brighter. Just a thought.
  8. Oct 3, 2009 at 8:57 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    could that affect your battry in any way though?
  9. Oct 3, 2009 at 8:57 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    hids will be alot better than stock halogens. just make sure they are adjusted to not blind everyone else
  10. Oct 3, 2009 at 9:10 PM
    iroc409
    Washington
    A red one
    Exactly! The idea is there is a substantial voltage drop in relatively weak stock wiring, which is bypassed entirely by the wiring harness. The cost to build one is fairly minimal.
    Do you lose any range aiming the HIDs down, and are they still overpowering for other drivers in rural areas? I definitely would like to try them (I bought 4300k). There was a Volkswagen that had them the other day that drove past me, and he nearly blinded me in broad daylight LOL.
    By driving lights I meant auxiliary lighting, or off road lights that I can't use in traffic. If the company I bought my light bar ever actually ships it, I have a set of 240 Blitz lights to go on the truck.
  11. Oct 3, 2009 at 9:16 PM
    ODICA
    ODICA 06 TACOMA 4X4
    Earl
    Beaumont, CA
    06 4X4 SR5
    I think I know exactly what your talking about, I've been running them in my lights for almost two years before I changed them to HID's. I had run the 100-120W Headlights and Fog lights as well. And i didnt had any problem in melting.
    There bright but the HID's :thumbsup: are brighter.
  12. Oct 3, 2009 at 11:05 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    HIDs are safer: wont melt your wires and can see more.
  13. Oct 6, 2009 at 12:49 PM
    iroc409
    Washington
    A red one
    Thanks for the info, all. I am going to try the HIDs when I get time to stick them in. I like the idea of them, that's for sure. Since I drive with my lights on all the time, I also like the idea of reducing the power load.
  14. Oct 7, 2009 at 8:30 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    upgrading to heavier wire will increase your light output on standard halogen systems. The manufacturers run the thinnest wire they can to save weight, cost, space, etc. Thinner wires have more voltage drop. Less voltage = less output from filment bulbs.
    Ideally you would run a relay at the lamp housing. That way you can have they shortest possible run of thick wire and use thin wire to trigger the relay. http://www.sylvaniaautocatalog.com/sylvania/gen_tech_info.htm
    "In incandescent lamps, the filament resistance, temperature, current, watts, light output, and life are all greatly affected by the voltage. Empirical equations are available, relating those parameters to voltage over ranges of as much as 10% from nominal voltage. The designer may improve one parameter by changing the voltage, but in doing so shifts all the other parameters. For example, the life varies so that a small decrease in voltage will greatly extend the life; but the light output will simultaneously decrease as the fourth power of that voltage. The nomograph and curve diagrams below show the interrelationships of current, candlepower, and operating life to voltage."
  15. Oct 7, 2009 at 8:40 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    Why not just get brighter headlights? Like Syvania Siverstars? Mine are night and day difference from stock.
  16. Oct 7, 2009 at 9:03 AM
    viperstd
    Maryland
    agreed.. and the silverstars in my 1999 S-10 with an upgraded harness are brighter than my silverstars in my Taco with a stock harness... food for thought.
  17. Oct 7, 2009 at 9:11 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    All three pairs of silverstars I have had in the past have ALL died before a years time. I could never warrant spending 40 dollars each year for 'average' bulbs.. Poor build quality IMO.
  18. Oct 7, 2009 at 9:24 AM
    viperstd
    Maryland
    kind of thread jacking here, but...
    I have had great luck with them. The ones in my dime have ~40,000 miles over 3 years on them so far. They are still bright. ymmv
