Headlight Wiring Assistance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoshS, Aug 31, 2019.
  1. Aug 31, 2019 at 9:43 PM
    JoshS
    JoshS [OP] Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    Hi all,
    I'm trying to mod my headlights to disable the stock amber DRL, and change the default DRL to the outer LED light bar that my aftermarket headlights have (see photo):
    I still need the blinkers to work, so I'm thinking a may need to combine the DRL toggle mod + some frankenstein wiring to get this to work.
    Here's the wiring diagram I'm referencing:
    https://www.customtacos.com/tech.ol...6toyewd/06toypdf/ewd/2006/tacoma/h/em01d7.pdf
    Here's the headlights:
    https://www.ebay.com/itm/Jet-Black-...RL-Bar-Projector-Headlights-Pair/382956118230
    Looking for advice from anyone with experience in this area, or someone who has accomplished this before.
    Thanks!
  2. Sep 3, 2019 at 4:15 PM
    JoshS
    Josh
    Here's a screenshot of the connector to the LED bar
  3. Sep 3, 2019 at 4:20 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    I wanted to do this too but I couldn't find out how. Not sure if you can with the Spyder/aftermarket headlights
  4. Sep 4, 2019 at 8:56 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Easiest way to disable the stock DRLs is going to be to switch to a regular flasher module & the jumper block for a non-DRL truck. I got a SmartTap for mine since I wanted to put in LED bulbs anyway, and I really like it. I don't see much sense in trying to frankenstein stuff... the whole point of the factory weird DRL module/flasher is to have DRLs and turn signals out of the same bulb anyway.
    If it were me, once I did that, I'd just wire the LED bars to an ignition-hot circuit (if you want them on ANY time the ignition is on) and bada-bing, daytime (well, anytime, I guess) running lights. If you wanted them only on when the truck is on but the headlights aren't, or like that with an override to turn them on even when the headlights are on, that's not too hard to accomplish with a relay and/or switch.
    12TRDTacoma and Muddinfun like this.
  5. Sep 4, 2019 at 9:11 PM
    JoshS
    Josh
    Looks like I have more research to do, the SmartTap isn't quite what I was going for.
    Would it be a bad idea to tap into the live wire for the amber DRL and run that to the connector for the LED bar, and then snip the DRL wire to the amber bulb, and snip the live wire running from the harness to the LED bar? I assume I'd need to do some sort of add-a-fuse or risk burning up my wiring harness.
    see crappy paint fig (black=ground, red=live)
  6. Sep 5, 2019 at 4:11 AM
    Muddinfun
    Muddinfun Well-Known Member
    So, then the LED will become the turn signal and you will get hyperflash and you will still need to get a LED flasher. Either a $10 basic flasher or a $60 Smart tap flasher and the grey plastic jumper block. I REALLY like the cool things the Smart Tap flasher does. The most used feature is the departure lighting.
  7. Sep 5, 2019 at 12:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What would be neat if you could make the light bar on the light your drl and your blinker.
  8. Sep 5, 2019 at 8:37 PM
    JoshS
    Josh
    Even if I only re-wired the amber DRL wire? From the diagram, it appears as though the stock DRL wire and the blinker wire are separate
  9. Sep 5, 2019 at 11:32 PM
    Muddinfun
    How many wires are there going to the front turnsignals?
  10. Sep 5, 2019 at 11:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Truthfully I would just get a switch from On Board air designed to look like an OE switch. Put it in a blank location and run it that way with a relay. That way you can run the new DRLs anytime you want. You can either leave them always off or always on along with the factory DRLs or you can turn them off and just run the factory DRLs. No sense in frankensteining the circuitry if there is no need to.
  11. Sep 7, 2019 at 10:57 AM
    JoshS
    Josh
    Three
  12. Sep 7, 2019 at 11:02 AM
    Muddinfun
    Hhhhmmmm, not sure then. I'm more familiar with '05-'11 that only have 2.
  13. Nov 16, 2019 at 1:16 PM
    PErsing
    PErsing Well-Known Member
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Caliraised 52" curved lightbar, Fox Shocks, TacomaBeast projector headlights
    I had this same issue. I have spyder headlights and did the stealth dtrl mod and all it does is dim the amber lights. Haven’t come up with much after lots of research either
  14. Nov 17, 2019 at 11:35 AM
    caribe makaira
    Caribbean, Puerto Rico
  15. Nov 17, 2019 at 11:52 AM
    caribe makaira
  16. Nov 17, 2019 at 12:09 PM
    JoshS
    Josh
    Thanks for the help everyone
  17. Nov 19, 2019 at 8:23 AM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    So if I cut the green wires in this photo I can eliminate my parking lights? I have a 2012 Tacoma with spyder headlights. The stealth mod only dims my drl’s when I cut the green with red striped wire in the cab.
  18. Nov 19, 2019 at 8:37 AM
    caribe makaira
    I don't know how the Spyder headlights are wired. Cutting the green with red stripe eliminates the DRL on the Tacoma.
  19. Nov 19, 2019 at 8:58 AM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Correct, but for me all they did was dim. That’s why I’m confused
  20. Nov 19, 2019 at 9:22 AM
    caribe makaira
    DRL's in that year is tied to the TURN signal, Vehicle ON DRL's ON, TURN selected DRL's OFF on selected side. Headlights selected DRL's OFF.
    If you want the LED on the Spyders to be ON & Bright always, then you'll need an IGN/ACC fused source to them.
