Headlight Wiring Assistance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoshS, Aug 31, 2019.
  1. Nov 19, 2019 at 6:19 PM
    PErsing
    PErsing Well-Known Member
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Caliraised 52" curved lightbar, Fox Shocks, TacomaBeast projector headlights
    Sorry, I wish I was more inclined with this subject, but here are my Spyder headlights and the red and green wire I cut (like it said to in the stealth mode mod) only allowing the amber DRL's to dim. I want the white led DRL to be on which it always is, just don't want the amber lights to be as well. if I can disable them and only have them as turn signals that would be great.
  2. Nov 19, 2019 at 7:45 PM
    caribe makaira
    Caribbean, Puerto Rico
    So...maybe the Spyder's have a internal connection that shares the white led juice...can you show the rear of the lamps n wires? the website has a generic instructions for those headlights.
  3. Nov 21, 2019 at 10:52 AM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    here's the amber turn signal bulb with the wires
  4. Nov 21, 2019 at 12:32 PM
    caribe makaira
    Need to see the rear of the Spyder Headlight...
  5. Nov 21, 2019 at 5:25 PM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    I will send photos tomorrow when I get a chance. Say I cut the green wire in the photo? Is that going to do what I want? Or will it throw a code or something? Thanks for all the help
  6. Nov 21, 2019 at 6:12 PM
    caribe makaira
    You'd loose the PARKING illumination to that connector and light (Left side).
  7. Nov 22, 2019 at 1:15 PM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
  8. Nov 22, 2019 at 1:16 PM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    second to last photo with the green and white w/ black stripe wires is for the white drl which is all I want on during the day
  9. Nov 22, 2019 at 1:36 PM
    caribe makaira
    I don't see where the yellow (or light blue) wires from the DRL & Turn signal wires go into the Spyder headlights...
  10. Nov 22, 2019 at 4:40 PM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    All the wires that go into the headlight are there. Maybe they’re a different color? There is a dark blue wire
  11. Nov 22, 2019 at 5:02 PM
    caribe makaira
    If you remove the connector to with green wire and white with black runner you loose the Spyder DRL? or is there an internal wire going to them from the turn signal? You mentioned the DRL dims.
  12. Nov 22, 2019 at 7:20 PM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Correct. The green with white and black stripe powers the sideways u shaped white drl. The yellow, white and green runs the amber drl/turn signal. And the black, blue and red runs the hi/low beams
  13. Nov 22, 2019 at 7:22 PM
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    So there is no power from the turn signal running the sideways u shaped drl.
  14. Nov 22, 2019 at 8:12 PM
    caribe makaira
    So you could then tap into a fused IGN/ACC source to substitute (cut or not use) the green (Parking) wire.
  15. Nov 22, 2019 at 9:08 PM
    #35
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Will I get hyper flash? If I cut the green wire? Why would I need to tap into another power source? I’m not the smartest when it comes to this stuff...
  16. Nov 23, 2019 at 8:01 PM
    #36
    SHANTOU
    SHANTOU Well-Known Member
    2014 MGM DCLB TRD SPORT
    Which grill you is that? I want one for my 14 as well
    #36
  17. Nov 23, 2019 at 10:24 PM
    #37
    JoshS
    JoshS [OP] Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    Just one of the TRD pro knock-offs. Around ~$125 on eBay. ~$400 if you want to go OEM.
    #37
  18. Nov 24, 2019 at 7:09 AM
    #38
    caribe makaira
    Ok, disregard the post on getting a ACC source for the LED's.
    With the cut wire (green with red stripe) you loose the DRL function on the TURN signal, but this lamp also gets power to illuminate from the Parking circuit. I'm thinking you might have a Canadian version or the Parking settings is always on. And/or the LED's only illuminate with the Parking circuit, making the TURN lamp illuminate also. The Parking wire to the TURN lamp would need to be removed. (No need to cut) Tape the removed terminals (blue & yellow) and a cover hole in connector. There are plugs specific to that connector.
  19. Nov 24, 2019 at 10:41 AM
    #39
    caribe makaira
    Another option: replace the dual filament lamp for a single filament.
    You don't need to cut or de-pin the turn signal connector.
  20. Nov 24, 2019 at 7:57 PM
    #40
    PErsing
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Thank you for all the help again, I had thought a single filament would do the trick. I ended up cutting the green wire and caping them so they are all sealed up. Looks much better now.
