Headlights (am i fu**ed?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StormTrooper, Nov 30, 2009.
  1. Nov 30, 2009 at 2:52 PM
    StormTrooper
    StormTrooper [OP] Well-Known Member
    Ron
    Maryland
    08 Base Flowmaster Super 44 w/ K&N drop in
    Bed Cap,K&N Air Filter,Chrome Pieces,Flowmaster Exhaust,Neon on inside, Heavy Duty Custom Floormats ( Tacoma ), Tint 20%, Blue license plate lights, Various decals, LED Projector Halos headlights, JVC head unit stereo
    i bought the halo projecter headlights for my 2008 toyota tacoma and they worked great until now, the left headlight doesnt work... all of the other lights work ( turn signals, bright beams, and halo rings ) but that main headlight wont come on anymore in the left headlight... i tried to see if i can replace a bulb or something and i cant do it. do i get another headlight or what?
  2. Nov 30, 2009 at 2:54 PM
    jonny
    jonny Betty White Edition Heep ZJ
    relax dude :laugh:
    check the bulb
  3. Nov 30, 2009 at 2:55 PM
    StormTrooper
    Ron
    Maryland
    but theres the bulb part is covered in rubber stuf, so i cant get into it
  4. Nov 30, 2009 at 2:56 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    doesnt the rubber part turn off or something? i dont remember it being all that hard when i replaced my bulbs. just go tinker with it some
  5. Nov 30, 2009 at 2:57 PM
    jonny
    maybe someone with the ebay style projectors can chime in...
    but i would assume you can change the bulb.
    there has to be a way to pull off the rubber grommet and access the bulb.
    pull the headlight off the truck and inspect it if you cant reach it while installed
  6. Nov 30, 2009 at 3:00 PM
    StormTrooper
    Ron
    Maryland
    okay thanks ill try :( . ill show u a pic of whats on it...
  7. Nov 30, 2009 at 3:00 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    it is easy to pull off that rubber, to check the bulb is it ok or not.
    Don't worry. By the way, did you use HID on it?
  8. Nov 30, 2009 at 3:01 PM
    jab08
    jab08 Well-Known Member
    Alabama
    02 T4R 4wd
    This is the only rubber part thats in front of mine. All I have to do on mine is pull it right off. There has to be a way to get to them.
  9. Nov 30, 2009 at 3:05 PM
    StormTrooper
    Ron
    Maryland
    okay i got the rubber cap off, but how do i tell if the bulb is okay or not?
  10. Nov 30, 2009 at 3:08 PM
    StormTrooper
    Ron
    Maryland
    this is it, but how can i see if the bulbs ok?
  11. Nov 30, 2009 at 3:08 PM
    StormTrooper
    Ron
    Maryland
    and no it wasnt HID
  12. Nov 30, 2009 at 3:09 PM
    jab08
    Alabama
    02 T4R 4wd
    Does it look burnt? Can you see if the element is broken/burnt. If all else fails switch the light out with the one that works.
  13. Nov 30, 2009 at 3:10 PM
    StormTrooper
    Ron
    Maryland
    ill have to try all that tomorrow, so where can i find another bulb like that?
  14. Nov 30, 2009 at 3:12 PM
    jab08
    Alabama
    02 T4R 4wd
    That wire pushes into a slot. All you have to do is push the tab in and then down or up depending how its designed, and then the bulb will virtually fall out.
  15. Nov 30, 2009 at 3:12 PM
    Mellow
    Mellow Well-Known Member
    Dallas, TX
    08 Ext Cab SR5 4-Cyl Prerunner
    I don't know anything about the projector headlights but the bulb should come out, there my be a pin holding the bulb to the headlight or it may twist to lock in place... but, it has to come out as bulb do go out and need to be replaced.
    Once you get it out just look at the filaments to see if they are broken, you could also take the other one out and install int in this connector to see if it works .. if it does then you need a new bulb.
  16. Nov 30, 2009 at 3:13 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You should be able to find it anywhere. Wal-mart, Target, any auto shop...etc...:cool: If your that uncomfortable, take the bulb with you.:rolleyes:
  17. Nov 30, 2009 at 3:14 PM
    StormTrooper
    Ron
    Maryland
    okay thanks alot guys
  18. Nov 30, 2009 at 3:15 PM
    jab08
    Alabama
    02 T4R 4wd
    Im willing to bet it is a H1 bulb. You can find one at any autoparts place for like $8-$10 or brighter bulbs like silverstars for $20 per bulb.
  19. Nov 30, 2009 at 3:16 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If it isn't the bulb, check your fuse for that particular light. The location of the fuse is described in your owners manual.
  20. Nov 30, 2009 at 3:19 PM
    StormTrooper
    Ron
    Maryland
    yeah i checked all the fuses, theyre all good. ill just try and get a better look at how to get the bulb out tomorrow in the daylight cuz theres scres and pins and all this crap lol
