Headstrong off road bilstein kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gen1tacotime, Aug 30, 2016.
  1. Aug 30, 2016 at 5:22 PM
    Gen1tacotime
    Gen1tacotime [OP] Well-Known Member
    Anyone know how good this kit is? It's bilstein 5100s all around a Deaver AAL in the rear and old man emu 2882 coils up front with all the assembly parts.
    This would be to replace a spacer lift. My total would be $720 with front strut assembly and a diff drop kit.
    Also are the 2882 coils right for a double cab 4x4? I heard they ran a little stiffer than the 2880 (stiff ride doesn't bother me too much) but the 2882 settles less over time.
    So in all how is the kit? And should I order the 2880, 2881, or 2882 coils?
  2. Aug 30, 2016 at 5:57 PM
    RHilllovestacos
    RHilllovestacos Member
    2001 Toyota Tacoma Double Cab 4x4
    - Flowmaster 40 series muffler, custom raised piping to get above leafs - K&N Cold Air Intake system - Rancho Quicklift struts - Rancho 9000xl Rear monotube shock absorbers - 2" Lift
    Check out the Rancho 2.5" quick lift for the front, and the 9000xl's in the rear. Just put em on my 01 4x4 and they're awesome! I have an awesome mechanic that hooked me up and I had them put on for just under a grand. The best part of these shocks is the adjustable dampening system. You can just reach under and turn a knob to adjust stiffness depending on terrain, and they even make a digital remote that you can program for specific terrains and change the suspension at the press of a button!
    http://www.gorancho.com/products/leveling-systems/quicklift-loaded-leveling-system
  3. Aug 30, 2016 at 5:58 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    The 880 and 881 coils are a 500# spring. The 882 is a 590# spring, so yes they will be stiffer and will settle less with no added weight. The diff drop is a waste of your money imo. It does not help with your cv's that I can tell. I have one and my boots still ripped. And to answer your question "how good is this lift?" Besides the bilstiens shocks is the most decent lift you can get for your truck before headed into high quality stuff like kings,icon,etc. At this pint why not just go with OME shocks as well. Better track record then the billys.
  4. Aug 30, 2016 at 5:59 PM
    Gen1tacotime
    They only show a 1.75 inch lift
  5. Aug 30, 2016 at 6:02 PM
    FirstGen Jer
    Jeromey
    Which ones?
  6. Aug 30, 2016 at 6:04 PM
    Gen1tacotime
    The link you sent me
  7. Aug 30, 2016 at 6:06 PM
    Gen1tacotime
    Also I'm looking at the Billy's because they would be over $100 dollars cheaper and that's a big deal for me right now. I've also been recommended the bilsteins about a thousand times
  8. Aug 30, 2016 at 6:06 PM
    Gen1tacotime
    Whoops quoted the wrong person about the 1.75 inch sorry
  9. Aug 30, 2016 at 6:07 PM
    Gen1tacotime
    I'm only seeing a 1.75 inch lift for the first gen
  10. Aug 30, 2016 at 6:10 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    The Bilstein 5100s have 3 or 4 lift settings and one of them is 1.75. However the 882 springs provide about 2.5-3" when the Billys are set at 0 lift.
  11. Aug 30, 2016 at 6:12 PM
    FirstGen Jer
    Jeromey
    Bilstiens is what everyone on here gets at first because they where cheap and then 90% of them regret it later. That's just my 2 cents. The best way to make the best educated decision is to do some reading on the suspension threads. You will see many opinions of what has worked best or sucked and why. Here is a couple OME threads with lots of pics of the different spring set-set-up and so on https://www.tacomaworld.com/threads/1st-gen-ome-882-and-dakar-lifts.372245/
    https://www.tacomaworld.com/threads/old-man-emu-setups-on-1st-gen.141055/
    ODNAREM likes this.
  12. Aug 30, 2016 at 6:13 PM
    Gen1tacotime
    Yeah I quoted the wrong person on that. I was talking to the guy that sent the Rancho link
  13. Aug 30, 2016 at 6:32 PM
    Gen1tacotime
    I feel like I should explain my situation haha. So I bought the truck with a lift already on it. It's a shitty spacer lift with a block lift on the back with factory shocks and springs. I'm worried about it possibly damaging the truck and also hate the ride quality. So I'm looking for something to last me 2 to 3 years (I only off road a few times a year) while I pay the truck off until I can afford to do some serious fab work and get a 3 inch long travel kit put on. So it comes down to either the bilstein/ome kit or the bilstein/eibach kit from toytec. I have a pretty strict budget and unfortunately the full ome kit is about $200 outside of that budget. Would I be able to get by with the bilsteins for a couple years? Even if it's only 2 years and then swap them out for the ome shocks.
  14. Aug 30, 2016 at 6:37 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    They should. Yours lasted around 15 or so years.
    ODNAREM likes this.
  15. Aug 30, 2016 at 6:38 PM
    FirstGen Jer
    Jeromey
    Most definitely man. The billys will work for sure. There is just a lot of guys that ask these same questions so I tend to try to help people get the better option the first time around. I was in the same boat as you a year ago and had all these same questions. Really though just read through the first few pages at least of that ome thread I posted ton of experienced opinions and pics in there with what you are wanting.
    ODNAREM likes this.
  16. Aug 30, 2016 at 6:43 PM
    FirstGen Jer
    Jeromey
    Also ask for marie at headstrong she is awesome and let her know you are a tw member (possible discount) when/if you order from them. Same goes for toytec. I believe they offer a 5% code discount for tw
    ODNAREM likes this.
  17. Aug 30, 2016 at 6:47 PM
    Gen1tacotime
    For sure. So I read a bunch in one thread and had a question. They were all saying that the 882's are heavier spring loads and are taller than the 883's. So should I do 883s or 882s? I head having a double cab makes a difference so I just don't know what springs to go with
  18. Aug 30, 2016 at 6:56 PM
    RHilllovestacos
    The site says 1.75" you're right, but when I put mine on all in all it gave me about 2", it's enough lift for me, and what I do, and I love the adjustability option on the dampening. If you use the truck more as a DD, and off road occasionally, and don't want to spend more than a grand the Rancho's are your best option in my opinion.
  19. Aug 30, 2016 at 7:10 PM
    FirstGen Jer
    Jeromey
    Ya I think there was some confusion years ago with the spring rates and such. The 883 is the heavy load spring. If you had a winch and plate bumper up front that would be your option. Since you are a double cab go with the 882.
  20. Aug 30, 2016 at 7:18 PM
    Gen1tacotime
    OK cool. Might be getting a little paycheck tonight. We will see how that goes. May just end up with the full ome kit with a Deaver AAL in the rear if I get enough on that check.
    ODNAREM and FirstGen Jer[QUOTED] like this.
