Headunit won't power on, help!
Discussion in 'Audio & Video' started by GoDeacsWFU23, Dec 29, 2011.
  1. Dec 29, 2011 at 5:34 PM
    GoDeacsWFU23
    GoDeacsWFU23 [OP] Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
  2. Dec 29, 2011 at 5:37 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Ok what I'm referring to as the remote wire is the 12 volt ignition wire.
  3. Dec 29, 2011 at 5:41 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Here is what I have:
  4. Dec 29, 2011 at 5:42 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Ok, on the left side of the picture the disconnected wires are the dimmer which is the orange/white wire and ignition/switched 12v which is the red wire
  5. Dec 29, 2011 at 5:43 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    the blue wire disconnected in the center is the power antenna wire
  6. Dec 29, 2011 at 5:43 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    on the right side of the picture the disconnected wires are the dimmer ground which is orange/black and the accessory wire which is red
  7. Dec 29, 2011 at 5:46 PM
    TacoDawgfan
    Georgia
    Ok so the harness has a 12 ignition lead, what wire from the stereo is the same. They should be connected. Maybe the pink one?
  8. Dec 29, 2011 at 5:48 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    so i need to take my blue/white wire coming out of the hu which is the remote turn on lead and hook that to the red ignition/switched wire coming out of the harness which is not hooked to anything.
  9. Dec 29, 2011 at 5:48 PM
    TacoDawgfan
    Georgia
    yes
  10. Dec 29, 2011 at 5:49 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    the pink/black wire on the right is the audio interrupt, i think for the blue tooth
  11. Dec 29, 2011 at 5:49 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    i will try this and hopefully this will take care of the problem!
  12. Dec 29, 2011 at 5:50 PM
    TacoDawgfan
    Georgia
    If this doesn't get you going then I'm lost. ;)
  13. Dec 29, 2011 at 5:54 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    yeah, still nothing
  14. Dec 29, 2011 at 5:54 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I'm going to disagree with the other poster here and say no. The red wire coming from the headunit should be connected to a 12 volt positive source of power that comes on and off with the ignition key. That should be the red wire on your adapter harness that plugs into the trucks wiring.
    The remote turn on lead is for turning on an external amp if you have one.
    You should be able to just match colors on the two harnesses. That's how they are designed to work.
  15. Dec 29, 2011 at 5:54 PM
    #35
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    i am going to go across the street to my neighbor and see if he can figure it out, thanks for your efforts!!!!
  16. Dec 29, 2011 at 5:56 PM
    #36
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    the red wire coming out of the hu is labeled as accessory
  17. Dec 29, 2011 at 6:04 PM
    #37
    TacoDawgfan
    Georgia
    I'm not trying to argue but I've done many stereos and If I there in person I could get it. I don't know what wire is what from here. I know they use weird color coding so idk? But it's been 6 years or so since I've done one. Anyway just trying to help. Hope I didn't lead him wrong. I know it's not complicated, just need to be there in person I guess. Hopefully his neighbor can help.
  18. Dec 29, 2011 at 6:13 PM
    #38
    alwaysat8k
    alwaysat8k My truck is slow
    Virginia
    2012 Access Cab SR5 4cyl 5spd 5lug
    Fat Bobs 2.75" spacer, 1.5" Long AAL in rear
    looks like your 12v isnt hooked up (red wire). that will get u no juice. mate the colors. very simple. red to red etc. that wiring schematic just explains toyota wiring harness plugs.
    the blue with white is your remote turn on - which is for an amplifer hookup. the blue one is for the power antenna, mate it to the other blue. understood we dont have power antennas, but sometimes there is juice running through there for some reason.
    the orange wire is for the dimmer, which when you turn your lights on it dims the brightness of the deck.
    i can almost 100% garuntee you need to connect to the two 12v's, which are the two reds you have disconnected.
    good luck
  19. Dec 29, 2011 at 6:15 PM
    #39
    jkc
    jkc Member
    Baltimore
    06 TRD Double Cab
    from what i can see you need to attach the red to red. turn to page 111 of your manual there is a wiring diagram. this unit is a nav/dvd unit. i have yet to install one but if your parking brake wires are not hooked up then that could be your issue.
  20. Dec 29, 2011 at 6:17 PM
    #40
    TacoDawgfan
    Georgia
    Then what is the yellow w/the box on it? I thought maybe that was an in-line fuse making it the 12v. :notsure: Idk why the power wouldn't be red but I thought the last time I did an install it had weird color combinations.
