Headunit won't power on, help!
Discussion in 'Audio & Video' started by GoDeacsWFU23, Dec 29, 2011.
  1. Dec 29, 2011 at 6:21 PM
    #41
    joes06tacoma
    Joe
    Central Coast, CA
    Yellow is constant power. Runs the internal amp inside the deck and maintains the memory when the truck is off. Every deck I have installed had yellow for constant with inline fuse and red for switched on power. "accessory" refers to the key position.
  2. Dec 29, 2011 at 6:25 PM
    #42
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It should be red to red. These harnesses are made to match right up. The color coding is standardized throughout the industry.
  3. Dec 29, 2011 at 6:28 PM
    #43
    GoDeacsWFU23
    GoDeacsWFU23 [OP] Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    the yellow is the 12v power with an inline fuse
  4. Dec 29, 2011 at 6:29 PM
    #44
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    ok, i will try red to red
  5. Dec 29, 2011 at 6:33 PM
    #45
    alwaysat8k
    alwaysat8k My truck is slow
    Virginia
    2012 Access Cab SR5 4cyl 5spd 5lug
    Fat Bobs 2.75" spacer, 1.5" Long AAL in rear
    sorry didnt mean to be confusing, both are 12v.
    yellow is for constant 12v (thats why it has a fuse in it)
    red is for ignition switch turn on 12v (this initiates when the head unit turns on - when your truck key is in accessory position on the ignition etc)
    my apologies.
    still - mate red to red together and whola!
    hope it works for you dude. i love new headunits :D
  6. Dec 29, 2011 at 6:34 PM
    #46
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    guess what?!? RED TO RED WORKED!!!! I HAVE POWER!!!!!
  7. Dec 29, 2011 at 6:35 PM
    #47
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    THANK YOU ALL SO MUCH!!!!! +1 REP FOR EVERYONE THAT HAD SOME GREAT ADVICE, EVEN IF IT WASN'T CORRECT!!!!
  8. Dec 29, 2011 at 6:36 PM
    #48
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Ok so it sounds like he should have it now then. I had it backwards, thought maybe the power was hooked up but not the "memory" wire, (my memory is going to sh*t :eek:). It has been a while though. Anyway sounds like this should be it. :pray:
  9. Dec 29, 2011 at 6:37 PM
    #49
    TacoDawgfan
    Georgia
    :thumbsup:
  10. Dec 29, 2011 at 6:40 PM
    #50
    alwaysat8k
    Virginia
    :woot:
