Heat&A/C fan stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mflarose, Dec 10, 2015.
  1. Dec 10, 2015 at 11:41 AM
    mflarose
    mflarose [OP] New Member
    2007 V6 Black Double Cab
    New to the community and need some help. My air system (both heat and A&C) started acting funny about 2 years ago and the fan would only work on the HI setting, but now that has stopped working as well. I looked behind the dash, literally the piece the dials are on and noticed that the connector directly behind the fan speed dial was burnt. Take a look at the pictures:
    Can anyone tell me where I can get a new connector? I cut it out already hoping the dealer or a shop I go to could either replace it or fix it but nobody has been able to help. I want to find a new connector and then just splice the wires back together.
  2. Dec 10, 2015 at 6:15 PM
    cortes24
    cortes24 Member
    Nick
    Northern nevada
    14 TRD Off-road model
    None yet
    Same thing just happened to my truck. stopped working about an hour ago. Worked fine all day, now it only works on the HI setting. definitely following this post.
  3. Dec 10, 2015 at 6:18 PM
    Erkon
    Erkon Well-Known Member
    Wisconsin
    2012 Pyrite Mica Tacoma TRD Supercharged
    Blower motor resistor took a shit
  4. Dec 10, 2015 at 6:28 PM
    cortes24
    cortes24 Member
    Nick
    Northern nevada
    None yet
    Man, this blows. Trucks not even 2 years old yet. I'll check it out. Thanks for the help.
  5. Dec 18, 2015 at 1:42 PM
    mflarose
    Update: Dealer told me that I'm pretty much screwed unless I can pull the exact same part out of another Tacoma at a junkyard, otherwise they would charge me for the entire wiring harness (and with the install) it would be quite a bit of money. Still searching for a replacement myself.
  6. Dec 18, 2015 at 2:48 PM
    Erkon
    Wisconsin
    MAYBE that one will MAYBE work?
  7. Dec 18, 2015 at 2:48 PM
    Erkon
    Wisconsin
  8. Dec 18, 2015 at 2:49 PM
    Erkon
    Wisconsin
    BAH, the connector tab is on the wrong side!
  9. Dec 18, 2015 at 7:44 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    First, try to disconnect the connector at the blower and inspect it. In my situation, I had the same burnt look at the resistor connector and at the flower connector. I think it was the blower connector problems that lead to high resistance at the resistor connector, causing it to burn. Fixing the blower connector fixed the problem for me. I did buy a new resistor connector on eBay. It was pretty cheap, I think less than $15.
