Heat Now Doesn't Work Properly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by R490, Jan 31, 2019.
  1. Jan 31, 2019 at 9:36 AM
    R490
    R490 [OP] Well-Known Member
    Upgrayedd
    VA
    Warmed my truck up for 10 minutes this morning with the heat on full blast. Went outside and it was barely warmer than the outside and the two middle vents weren't working at all.
    Is this normal?
    My entire 30 minute commute I had the heat on full blast, with the fan speed all the way up and it wasn't that warm until the last five minutes.
  2. Jan 31, 2019 at 9:40 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    thermostat or your control valve inside under the dash isnt working.
  3. Jan 31, 2019 at 12:09 PM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    If you want the heat to come on quicker, don't run the fan while the engine is warming up. With the "heat on full blast" you are effectively transferring the little engine heat into the heater core radiator and the engine will not warm as fast. Also, make sure you are on RECIRC. Wait a few minutes after starting and gradually increase the fan speed. It will heat up.
    My daughter called from Iowa; "Dad the heater is not working in my car (Camry). The controls are set to heat but only lukewarm air."
    Me: "Try turning the fan to low and drive a few more miles"
    Her: "It's working now"
    TireFire likes this.
  4. Jan 31, 2019 at 2:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no control valve.... Full coolant flow through the heater core all the time. Temperature is controlled by the blend door.
    JGO and PzTank like this.
  5. Jan 31, 2019 at 3:03 PM
    rdiddy_25
    rdiddy_25 Well-Known Member
    Rafael
    New Braunfels, TX
    2010 Tacoma DCLB 4x4
    Icon Stage 4 Suspension, Safari Snorkel
    This is correct
  6. Jan 31, 2019 at 7:58 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    In sub-zero or single digit temps your truck might not ever get to normal operating temp. I had ice on my windshield the other evening on my way home from work, I had the defrosters on high all the way home and 40 minutes later I still had ice on my windshield. It was blowing hot but the windshield was so cold that it did not warm it up enough to melt the ice.
  7. Feb 1, 2019 at 4:13 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I am on my 8th Toyota product spanning 1984-2015... not a one had a heater worth a damn. Not Toyota's strong suit in my opinion.
