Heat shield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jwtayl01, Nov 19, 2017.
  1. Nov 19, 2017 at 2:33 PM
    jwtayl01
    jwtayl01 [OP] Active Member
    Syracuse, NY
    09 SR5 Double Cab
    The heat heat shield above the cat on the driver's side came loose as I was fixing one connection point, the other two came loose as well. (this is a classic example of galvanic corrosion) I removed the heat shield. Can I leave it off?
    Thanks, Jesse
  2. Nov 19, 2017 at 2:41 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Ya you dont "have" to have it just make sure it was not protecting any wires or hoses
  3. Nov 19, 2017 at 2:51 PM
    20RustyTaco06
    20RustyTaco06 Well-Known Member
    Allen
    Dublin, GA
    2006 sr5 Tacoma DBL cab auto/4wd
    Complete Pioneer audio Supreme Suspension 3" spacer lift 255/75-17 Kuhmos/Sport wheels 1.25" wheel spacers Tint
    This time of year you may welcome the added heat....
  4. Nov 19, 2017 at 2:54 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
  5. Nov 19, 2017 at 4:06 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    only downside I can think of is the floorboard may get hotter, not sure how much hotter or if it will affect insulation and carpet and what not, never tried running with no heat shields.
