Heated Mirrors Kit - Interest / Update Thread (pic heavy)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Up2NoGood, Jun 13, 2015.
Would You Like To Sign Up For Heated Mirrors
  1. YES
    735 vote(s)
    95.5%
  2. NO
    18 vote(s)
    2.3%
  3. TLDR
    17 vote(s)
    2.2%
  1. Feb 26, 2018 at 4:04 PM
    #1701
    Pigpen
    Dan
    Northwest Montana
    You could just have one heated mirror
    I'd go to a salvage yard and buy an OEM mirror assembly, or get one from one of the guys putting on T4R or tow mirrors
  2. Feb 26, 2018 at 6:44 PM
    #1702
    Andretti
    Andretti Active Member
    Kansas City, Missouri
    2023 Tacoma TRD Sport, 2008 Shelby GT500
    I appreciate the suggestions. I will be doing some research to see what I can find.
    Thank You
  3. Feb 27, 2018 at 11:56 AM
    #1703
    Up2NoGood
    Up2NoGood [OP] Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    You would be okay with the kit partially installed, I would just leave the add a fuse not connected and then no power will be supplied to anything in the harness. As far as the mirror dilemma that is a new on for me. I guess you could talk to the family friend and see if there is a heated option for the aftermarket mirror housing he put on. If not then you might need to find a used OEM housing to put on.
  4. Feb 27, 2018 at 1:21 PM
    #1704
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    Andretti what has happened is that the body shop put an aftermarket mirror assembly on your truck. Sadly your only option is to find an OEM mirror assembly, nothing in your current setup will match anything that Toyota built. Yes it looks and is the same size but everything from the mirror to the drive motors are not interchangeable with an OEM unit.
    The mirror itself can't be removed from its backing if you wanted to try a heater pad as the mirror is held in with some sort of super RTV and you will just break the mirror trying to remove it. This mirror is not available from anywhere that I have found.
  5. Mar 1, 2018 at 12:59 PM
    #1705
    Andretti
    Thanks for the comments and suggestions. I just went ahead and bit the bullet and ordered a mirror from Toyota. Once I get it, I will get it painted to match the truck, do the mod, and then swap it out with the one that isn't factory thats currently on the truck. It may seem a bit extreme, but (while I have NO issue what-so-ever with the price of the kit to do this mod), I'd still rather not spend that kind of money to only get 'half' of the project working. I use both mirrors, so only having one that heats up really isn't an option.
    That all being said, I did go ahead and finish the rest of the install. All I will need to do once the new mirror is painted is do the mod, then put it on the truck and plug it in.
    Still, even with the issues I've had, I'm extremely happy with this kit and that I was able to get a hold of one. Thanks again for the opportunity.
  6. Mar 2, 2018 at 5:45 AM
    #1706
    CITY TACO
    Andretti no need to paint the cover on the mirror as you can order them in the color that your truck came in. They are all the same price be it black or red or blue.
  7. Mar 9, 2018 at 3:32 PM
    #1707
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Used my kit lots this week
    East coast is getting hammered with wet goopy snow that just loves to stick to the mirrors
    Super glad to have it
    Thanks Up2NoGood!
    jpereira2 likes this.
  8. Mar 20, 2018 at 8:19 PM
    #1708
    Admiral Awesome
    Admiral Awesome IG:Bucklaooooo
    anthony
    Houston Texas
    2012 DC TRD LT
    Camburg 3in LT kit fox shocks/bypasses 315-75-16 Scs f5 wheels gunmetal 16x8 Prinsu rack 40in heretic light bar Cali raised ditch light Baja squadron pros McNeil fiberglass fenders Adv fiberglass bedsides Volant intake
    Finally had time to install my kit been sitting in the garage since December lol.
  9. Jul 13, 2018 at 6:54 AM
    #1709
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    So as a 2015 owner who wants heated mirrors is there a Toyota P/N with the little blind spot mirrors in the corners as an option?
  10. Jul 13, 2018 at 7:00 AM
    #1710
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    LamzTaco likes this.
  11. Jul 13, 2018 at 7:03 AM
    #1711
    Greenbean
    Zack
    Western NC
    MadRiverTaco[QUOTED] likes this.
  12. Jul 13, 2018 at 12:17 PM
    #1712
    Greenbean
    Zack
    Western NC
    The left of steering wheel switch will also fit in one of the upper outer segments correct?
    I have a M/T and my clutch start cancel is in the middle.
    Tacosail likes this.
  13. Jul 13, 2018 at 12:43 PM
    #1713
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    It will fit on the top row yes. I only had 1 blank on the top middle and there was enough space and wiring for it to fit with no issues.
    Greenbean[QUOTED] likes this.
  14. Jul 13, 2018 at 1:01 PM
    #1714
    Greenbean
    Zack
    Western NC
    Saaweeettt!!!
  15. Jul 19, 2018 at 7:34 AM
    #1715
    alnilla
    alnilla Well-Known Member
    2014 TRD Sport
    Are the heated mirror kits still available?
  16. Jul 19, 2018 at 9:21 AM
    #1716
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'm not usually doing much on the heated mirrors during summer as it's a busy time for me (and slow time for heated mirrors lol). They are still available though.
    Lord Helmet and rmepilot like this.
  17. Jul 19, 2018 at 3:16 PM
    #1717
    alnilla
    2014 TRD Sport
    Yeah I would rather throw them in in the summer then come November I will be ordering a set here soon
    Thank you!
    G.T. likes this.
  18. Aug 5, 2018 at 5:34 AM
    #1718
    Bizcat
    Bizcat Member
    Andy
    2014 Toyota Tacoma
    Very interested! I already have the mirrors and switch. Just need the harness to do both sides. Let me know, thanks!
  19. Aug 23, 2018 at 2:40 PM
    #1719
    alnilla
    2014 TRD Sport
    Left of steering wheel
    5 min
    Green
    USA
    Send me a pm with PayPal information
    Thank you
    G.T. likes this.
  20. Aug 25, 2018 at 6:15 AM
    #1720
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    Have read thru almost this entire post (very time consuming) but wanted as much info as possible so I didn't ask a question that had already been answered. Still came up with one though. I want the new mirror switch option, amber illuminated when heating, 10 minute timer.
    Now to the question. I am debating switching to ProEFX heated, turn signal mirrors and wonder if you add disconnects at the mirrors ( or in the cab, wherever convenient) to your kits to make it a little easier to be able to swap mirrors later?
