Heated Mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tactical_Panda, Dec 9, 2022.
  1. Dec 9, 2022 at 6:25 AM
    Tactical_Panda
    Tactical_Panda [OP] Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    My 2015 DCSB does not have heated mirrors.
    How difficult would it be to add them? Is it even (easily) possible?
    TIA
  2. Dec 9, 2022 at 7:01 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Dec 9, 2022 at 7:06 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    If you're willing to do some Jerry rigging, you would just need the mirrors from a junk yard truck that are heated, some wiring, inline fuse and a on/off switch.
    Would 3rd gen mirrors/mounts fit right up?
    I'll park my 05 next to a 3rd gen next week and tak a look
  4. Dec 9, 2022 at 7:17 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Search for 4runner mirrors. Theres a thread on here somewhere about swapping early 2nd gen mirror to 4runner mirrors with turn signals before the gen2.5s came out. Some of the 4runner back then had the heated mirror option. Plus they bolt right up. Just need to run the wires.
  5. Dec 9, 2022 at 12:08 PM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    GilbertOz and TacodriverSD like this.
  6. Dec 9, 2022 at 12:09 PM
    Hayden334
    Hayden
    Cullman, Alabama
  7. Dec 9, 2022 at 1:18 PM
    mark_tga
    mark_tga Well-Known Member
    2015 Tacoma DCSB
  8. Dec 9, 2022 at 1:35 PM
    TacodriverSD
    TacodriverSD Member
    2009 Tacoma SR5
  9. Dec 9, 2022 at 3:36 PM
    mark_tga
    2015 Tacoma DCSB
    Check my post above yours.
  10. Dec 10, 2022 at 6:28 PM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Thanks everyone.
  11. Dec 11, 2022 at 8:06 AM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    So the heated mirror install is an easy job if you have a bit of wiring know how. Got my kit from the user on here that was building the kit, unfortunately he has indicated he is now to busy to do it but maybe in the future. His kit was all plug and play, he had a great instruction manual that is still online that you can use to see how he made it. Toyota Sienna mirror glass were used and it is a direct fit, he has pics on the thread of the mirror boxes which show the part numbers.
    Now the main part, you can’t just use that switch that Hayden334 shows as this is only an on off switch and if you forget about it has the tendency to keep the mirrors on, shortening the element life. Not saying you can’t but it’s not recommended, buddy uses a timer chip that you do use the power mirror switch but you have to remove a spring inside it to make it a momentary switch. You need to take that mirror off the truck and take it apart to install the wiring and while you are at it go to your local pick and pull and find a set of older Rav 4 mirror signal lights as you will find the mirror was actually built for them. Correct color covers are available from Toyota. Somebody on here tried a set of third gen and he had to modify the door to accept the mirror assembly, lot of gaps that I could see.
  12. Dec 13, 2022 at 2:44 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    I installed SpotterMirrors on my 2014 AC V6 TRD OR about 8 or 10 months ago. I have not installed the heated-mirrors mod -- but I can vouch for the functionality & durability (so far) of the SpotterMirrors product itself. Super handy for reducing blind spots to almost zero, and so far they have been mechanically rock solid, even with a couple hundred cumulative miles of very bumpy dirt-road/forest-road 4WD driving.
    They hold their set position well and have not come loose from the mounts.
    Hayden334[QUOTED] and mark_tga like this.
  13. Dec 13, 2022 at 3:35 PM
    mark_tga
    2015 Tacoma DCSB
    Do the heated mirrors from them come with the heating element and we just need to wire it up?
    Hayden334 likes this.
  14. Dec 13, 2022 at 4:32 PM
    Hayden334
    Hayden
    Cullman, Alabama
    Yes.
    GilbertOz and mark_tga[QUOTED] like this.
  15. Dec 13, 2022 at 5:14 PM
    mark_tga
    2015 Tacoma DCSB
    Damnit. Now I have to buy them.
    Hayden334[QUOTED] likes this.
  16. Dec 13, 2022 at 5:53 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    I did the oem heated mirror diy mod about a month ago following the link that @mark_tga posted above. Used the spotter mirrors & the Highlander switch. Very happy with the spotter mirrors so far. Relatively easy, but somewhat time consuming, took me a weekend to complete once I got all the parts together.
  17. Dec 14, 2022 at 6:34 AM
    Hayden334
    Hayden
    Cullman, Alabama
    Did you find a time delay relay to use?
  18. Dec 14, 2022 at 6:04 PM
    Big Foot
    Washington
    2014 DCLB
    No, just a normal relay. The Highlander switch I used has a timer built in already
  19. Dec 15, 2022 at 5:43 AM
    Hayden334
    Hayden
    Cullman, Alabama
    Awesome, Some how I missed that.
  20. Dec 16, 2022 at 4:43 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I did this a few years back to my 2015 Dblc. Took a day and a half of monkeying around. Used 2013 Ist series 4Runner mirrors and modified my Tacoma mounts. Wiring plugs were changed so the mirrors operated normal from factory switch. Plug is in the door for the turn signal. Wired the puddle lights all the way. Heated mirrors were wired up with a timed relay. Not a beginner project but doable if you are comfortable with wiring and disassembly.
    GilbertOz and HellsWells like this.
