Heated seats and Wet Okole seat covers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LonghornTaco, Dec 3, 2008.
  1. Dec 3, 2008 at 12:57 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I guess this wouldn't be limited to Wet Okole seat covers, but that's what I'm gonna have (or at least will this Friday!)
    I was thinking about adding heated seats since I now live in the ice box of the USA, but I was wondering how much I would feel them through the seat covers if I put them under the factory upholstery...
    Any suggestions, tips, reports, experience, etc...? Also, what about putting it on top of the factory upholstery and under the seat covers? Somehow that sounds bad, just don't know for sure...
    Thanks!
  2. Dec 3, 2008 at 2:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have heated seats with RuffTuff seat covers that are padded on the seat side. You can feel the heat through them - and I really can't comment how they feel without the seat covers as I've never tried it that way.
    But, it's not something you wanna use for short trips. I've discovered if you turn them 'on' and let the truck warm up, they 'energize' and once you sit on the seat the heat comes faster (the heating pad has a sensor in it so it won't be on if nobody is sitting there). But it takes a bit. I have a 9 mile trip to work and it takes a couple miles before they're nice & toasty. Still better than nothing!!
    As for mounting the heating element inbetween your seat and seat covers - you'd have to make sure the heating element isn't gonna damage or melt your seat covers. Depending on the kit you get - you'd have to secure the heating element to the seat to prevent it from buckling up or moving out of place. You're better off installing the unit 'as directed' to avoid problems. Having the element in the seat as directed - helps keep the element in place and they don't move.
    http://www.lieblweb.com/TechLinks/HeatedSeat/Heatedseat.htm
  3. Dec 3, 2008 at 4:40 PM
    LonghornTaco
    Minnesota
    I knew that you did it (in fact, you're where I got the idea!) but I didn't realize you had seat covers as well...
  4. Dec 3, 2008 at 5:50 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    it's not the greatest solution but for now i've added these to my truck, at least for this winter until i can decide if i want to do better. you may even be able to tuck these between the standard seats and the covers - i'm thinking i might try that
    heated seat covers from target for $20
    http://www.target.com/Wagan-Heated-Auto-Seat-Cushion/dp/B000ANOUHQ/sr=1-1/qid=1228355271/ref=sr_1_1/192-0041820-9307444?ie=UTF8&index=target&rh=k%3Aheated%20seat&page=1
    they just plug into a 12V outlet. if i keep them for next winter too, i'll probably hard wire them to a switch or at least add a set of 12V outlets under the seat for connection (but they aren't switched - problem)
  5. Dec 3, 2008 at 5:56 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    i would think they would work under wet okoles?? for $20.. might be worth a shot? once you get you okoles on they dont move! :D
  6. Dec 3, 2008 at 5:59 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    I think it would and for $20 you can't go wrong - if they don't work give them to someone as a present for xmas :) on high they are very strong so definitely worth a shot. if someone tries it, post if it works or not!
