Heater core, maybe?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TBLTravy, Oct 26, 2024.
  1. Oct 26, 2024 at 5:59 PM
    TBLTravy
    TBLTravy [OP] Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    Driving today and for the first time had the smell of engine coolant coming in through the vents. Same smell with recirc on and off. Engine coolant level is spot on and isn’t low. Any ideas how to check without having to take it in?
    2019 SR5 33000 miles.
  2. Oct 26, 2024 at 7:08 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    Is the carpet wet
    shakerhood likes this.
  3. Oct 26, 2024 at 7:25 PM
    TBLTravy
    No. Pulled the mats and it feels dry.
  4. Oct 26, 2024 at 7:26 PM
    Midnight beauty
    White mountains AZ
    You could pressure test the system and see if it holds. If it doesn’t then look for the leak
    MGMDesertTaco likes this.
  5. Oct 26, 2024 at 7:26 PM
    Bishop84
    Bishop84 Well-Known Member
    Need to check for the dreaded bypass leak. You'll see pink stains on the back of the engine and underneath on the transmission bellhousing.
    There's no visible drips because its burning off before it his the ground.
    Hopefully I'm wrong.
  6. Oct 26, 2024 at 7:27 PM
    MGMDesertTaco
    When's the last time the coolant was changed? Does the smell go away after running the heater for an extended time?
  7. Oct 26, 2024 at 7:33 PM
    TBLTravy
    I did a drain and fill a little under two weeks ago. The smell seemed much less almost gone with the heat on. Much stronger smell with the ac on.
  8. Oct 26, 2024 at 7:34 PM
    TBLTravy
    I didn’t see any.
  9. Oct 27, 2024 at 4:36 AM
    TBLTravy
    Update. This morning, pulled cabin air filter and noticed mice / rat droppings on top of the filter. The filter smells exactly like the ac smells. Replaced filter. Any ideas on how to try and eat proof the truck aside from peppermint oil?
    any reason for the coolant like smell?
  10. Oct 27, 2024 at 5:35 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    You need to do the cabin air intake screen mod. That is about the only way to keep rodents out of your HVAC system. It's cheap and easy to do. Do NOT use plastic screen, wire mesh is the way to go.
    And what you are smelling is likely their piss. Yayyyyyy....
  11. Oct 27, 2024 at 6:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    TBLTravy[QUOTED][OP] likes this.
  12. Oct 27, 2024 at 6:10 AM
    TBLTravy
  13. Oct 27, 2024 at 1:54 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you could disconnect the heater hoses or pinch them and see if it goes away but you might have 2 problems
    and has the coolant level gone down
  14. Oct 27, 2024 at 4:21 PM
    TBLTravy
    Coolant level is at the full line. I switched out the cabin air filter and the smell is gone.
    RIX TUX[QUOTED] likes this.
  15. Oct 27, 2024 at 4:48 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If you get a coolant leak inside the air box the windshield can fog up instead of clearing with the defrost on. You can also attach a cotton swab to the drain hose to see if there’s any pink residue.
    TBLTravy[OP] and RIX TUX like this.
  16. Oct 27, 2024 at 6:15 PM
    RIX TUX
    did you ck the radiator also
  17. Oct 27, 2024 at 6:26 PM
    TBLTravy
    Good to know. I used defrost this morning and it cleared it right up. I also collected water from the drain and smelled it. No coolant smell.
  18. Oct 27, 2024 at 6:27 PM
    TBLTravy
    No I didn’t actually. But it would drop the reservoir to fill the radiator if it was leaking
