Heater Knocking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BluTaco, Sep 30, 2013.
  1. Sep 30, 2013 at 9:17 AM
    BluTaco
    BluTaco [OP] Member
    Cody
    Atlanta, GA
    07 Prerunner
    It's kind of hard to describe whats going on but bottom line is when I turn the heat on there is a very distinct knocking sound coming from behind the glove box. I haven't had much time to research where exactly it is coming from but somewhere around the fan behind the glove box.
    It only starts knocking when I turn the heat past about the 4th red bar on the dial.
    Anybody have any clue what this might be?
  2. Sep 30, 2013 at 12:09 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Yep, I had that happen... was a pile of acorns from the damn chipmunks. Only made noise when it was 4 or higher, just like you.
  3. Sep 30, 2013 at 12:24 PM
    BluTaco
    BluTaco [OP] Member
    Cody
    Atlanta, GA
    07 Prerunner
    man, i drive my truck daily so not sure how that can happen. But it has been getting colder at night so that may have something to do with it. How did you get it out? I'm assuming it comes from the engine side somehow?
  4. Sep 30, 2013 at 3:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This "knocking" could be the mixing plenum door servo.
    Read this: http://www.tacomaworld.com/forum/2nd-gen-tacomas/229312-blend-door-servo-malfunction.html
