Heater only works on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lukealive530, Jan 12, 2019.
  1. Jan 12, 2019 at 1:55 PM
    Lukealive530
    Lukealive530 [OP] Member
    Luke
    2014 Dopeass Tacoma
    I purchased a 2014 a couple months ago. The other week I noticed a heater only works on high. No other speed is functional. Still blows heat and AC, but only on high speed. Any ideas where to start?
  2. Jan 12, 2019 at 1:57 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    On my 06 I had the same issue. I had to replace the AC blower resistor (under the passenger dash) and it went back to working perfectly. Apparently it's a somewhat common problem.
  3. Jan 12, 2019 at 2:00 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Also, check the plug that plugs into the resistor. After reading about it, I was able to get all speeds working again after wiggling the plug. Worked for a couple weeks, then it quite again so I replaced the resistor and wired in a new plug.
  4. Jan 12, 2019 at 2:20 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    A trick to get it to kick on is hit or bump the fan underneath the glove box. I've replaced my resistor on my 2010 a few years back and it worked great. That being said I now have to bump the fan to get it to kick on again so I'll need to replace that part again.
  5. Jan 12, 2019 at 2:50 PM
    Lukealive530
    Luke
    2014 Dopeass Tacoma
    Awesome thanks for the helpful inputs! I'll try giving her the ol 1-2 when I get off work lol. I was hoping it wasn't something I had to dig too deep into for repair. Resistors arent too spendy. Thanks again!
    Toyotacrawler likes this.
  6. Jan 12, 2019 at 2:53 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Anything other than full speed has to go thu the resistor block.
    OKTACO and Lukealive530[OP] like this.
  7. Jan 13, 2019 at 5:55 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  8. May 24, 2019 at 5:33 PM
    mbenatar
    mbenatar Member
    Marten
    Browns Valley, CA
    2010 Tacoma TRD Sport 4x4 Double Cab
    None
    Thank you! I got all the parts. Unfortunately when I ordered 82998-12380, only one wire came with it and they charged me $10.00 for one friggen wire! Unbelievable! So frustrating! I still can't believe the audacity of charging $10.00 for a part that probably costs .03 cents to make. What a rip off! Anyway. Thank you for your help! Much appreciated!
  9. May 25, 2019 at 7:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well as I said in my post above:
    " Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires. "
