Heater resistor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goodend, Nov 11, 2021.
  1. Nov 11, 2021 at 9:46 PM
    goodend
    goodend [OP] Well-Known Member
    dave
    sw missouri
    2013dbl cab
    My heater motor sometimes does nothing.. at all speeds..found burn marks on plug to resistor at blower. Wiggling wire sometimes solves it for a day or two. Would resistor cause this connection problem r should I focus on cleaning and securing connection?
  2. Nov 11, 2021 at 9:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    whatstcp likes this.
  3. Nov 11, 2021 at 9:56 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I just replaced the plug, resistor, and motor plug. Works now
    TnShooter likes this.
  4. Nov 11, 2021 at 10:06 PM
    TnShooter
    Deogee
    STOCK
    I guess it’s worth mentioning.
    The High Speed doesn’t use the resistor.
    If you get nothing on High, check the blower plug and the switch on the dash itself.
    They too, have had some problems.
  5. Nov 11, 2021 at 10:25 PM
    WasatchDweller
    WasatchDweller Well-Known Member
    Anthony
    2010 Regular Cab 5MT 4WD
  6. Nov 11, 2021 at 10:31 PM
    stocko taco
    stocko taco Well-Known Member
    Az
    19 Nissan Armada
    Honda Accord OBS Chevy
    The resistor and plug have been updated to a square design along with different wire gauge. New Part numbers are listed in the pictures. https://www.ebay.com/itm/2005-2018-...RESISTOR-WITH-CONNECTOR-PIGTAIL-/323788974234
    Connector to blower motor may have issue too.
    ALLMOST FOR Compatible with Toyota Tacoma 2005-2016 Blower Motor Connector 90980-10916 6" 12ga Harness NEW https://www.amazon.com/dp/B07YXLJP18. I would inspect any connection to and from the blower motor and replace what has signs of overheating
