Heavily abused Tacoma, what mods should I do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4xtacoma, May 10, 2017.
  1. May 10, 2017 at 8:52 PM
    4xtacoma
    4xtacoma [OP] Well-Known Member
    Jake
    Grass Valley Ca
    00' sr5 trd 5 speed 4x4
    3 inch lift, 265 75 R16 mxt's
    Hi guys so I'm still a relatively new member, and I've had my Tacoma for about 4 months now. It's my daily and wheeling rig, it has a 3" spacer lift, 265 75 a/t tires. I bought it knowing that it can take a lot of abuse however I have had to repair quite a bit on it so far: new rear axle bearings and seals (breather got clogged with mud which caused the seals to leak into the drums), drum breaks rebuilt, new balljoints and outer tie rod ends, multiple wheel studs have broken which I also fixed, and a new alternator. I was looking for advise on what things usually fail under heavy abuse (on and off road), and what upgrades are helpful
  2. May 10, 2017 at 8:53 PM
    4xtacoma
    Jake
    Grass Valley Ca
    How she currently sits
  3. May 10, 2017 at 8:55 PM
    4xtacoma
    Jake
    Grass Valley Ca
    Alright, I really like the ammount of lift, what would be a good lift kit? I have about 3K total budget and I was thinking 5100's with an AAL in the rear
  4. May 10, 2017 at 9:31 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
  5. May 10, 2017 at 9:34 PM
    4xtacoma
    Jake
    Grass Valley Ca
  6. May 10, 2017 at 9:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Get a mid priced leaf pack from all-pro, OME, or and 5100's all around. Still have $$$ for wheels and tires. Look for deals on wheels and tires on here (wheels and tires for sale thread) and on Craigslist. You'll save close to 25-50% on wheels and tires that way. AAL is good for on road towing, but for off-roading get a decent leaf pack. If you can weld then you can consider longer rear springs, but for your budget it won't happen in you have to pay a fab guy. Consider staying SOA with one of those leaf packs I mentioned and your axle wrap will not be nearly the same and you'll handle way better on and off road.
  7. May 10, 2017 at 9:54 PM
    4xtacoma
    Jake
    Grass Valley Ca
    ok I will look into all those thanks guys
