Heavy Duty Bed Crossbars - Ready to Ship
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by KB Voodoo, Jan 4, 2015.
  1. Jan 4, 2015 at 5:15 PM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Designed for extra heavy items, like spare tires, surf boards, canoes, and RTT's.
    See this thread for standard duty bed brackets.
    Design details:
    - Constructed of 14 gauge steel.
    - Mounts by locking into factory cleat.
    - Black textured powder coated.
    - Can support a load of 400 pounds in the center of the bracket.
    - Slot on the top will accept a 3/8" bolt.
    - Works with stock side rail caps, or my aftermarket caps.
    Price is $185 per set, or $95 each.
    PM for shipping quote.
  2. Jan 4, 2015 at 5:24 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This is how they attach to the cleats.
    Kuntrykid and transworldmoto like this.
  3. Jan 4, 2015 at 5:30 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    Looks like a good product :thumbsup:
    Taco@NC likes this.
  4. Jan 4, 2015 at 9:16 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    When is the basket coming?
  5. Jan 5, 2015 at 4:42 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The low profile basket is coming very soon.
    The standard basket is already available.
  6. Jan 5, 2015 at 4:42 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    I'd be much more interested if it simply bolted on to the rail without the OEM cleat. Any options?
  7. Jan 5, 2015 at 4:47 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There are always options, but since I have a pile of these in my basement, this is what we have for right now.
  8. Jan 5, 2015 at 12:52 PM
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    I take it these will fit with stock bedrail caps as well?
  9. Jan 5, 2015 at 1:00 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Good question!!
    Yes, they work with the stock caps and my caps.
    Jared8907 likes this.
  10. Jan 9, 2015 at 9:48 AM
    BryanCO
    BryanCO Well-Known Member
    Bryan
    Pinedale WY
    06 TRD OR DCSB
    Would these work under a Bestop?
  11. Jan 9, 2015 at 4:12 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    They would not. You would want these brackets for that.
  12. Jan 9, 2015 at 9:11 PM
    BryanCO
    Bryan
    Pinedale WY
    06 TRD OR DCSB
  13. Jan 9, 2015 at 9:13 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  14. Jan 10, 2015 at 7:22 AM
    hygieneboy
    hygieneboy Well-Known Member
  15. Jan 10, 2015 at 7:31 AM
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Wow...those look nice. If only I could mount a Yakima Rocket Box on them.
    12Tac
  16. Jan 10, 2015 at 12:56 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Why couldn't you?
  17. Jan 12, 2015 at 8:35 AM
    BryanCO
    Bryan
    Pinedale WY
    06 TRD OR DCSB
  18. Jan 12, 2015 at 8:48 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  19. Jan 16, 2015 at 9:23 AM
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    Granted, these are the standard bed brackets and not the HD version under discussion here. I'd planned on home-brewing a new set of hardware, but luck would have it that the standard Yak mounting brackets worked perfectly. That luck probably wouldn't extend to the HD brackets... but I can't imagine how it wouldn't be possible.
  20. Jan 16, 2015 at 10:01 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This is an excellent example of how to put these babies to use, and it should work for both the standard duty bracket, and the HD bracket.
