Heavy tires vs 4-bangers
Discussion in '4 Cylinder' started by hutch606, Aug 23, 2011.
  1. Aug 23, 2011 at 9:54 PM
    hutch606
    hutch606 [OP] Well-Known Member
    Who's running real AT tires (50ish lb tires) on their 4-bangin' 4wd trucks (I'm access cab, MT)? 95% of my miles are on-road, but the extra 5% can pretty much suck. I've been a huge fan of old-school BFG ATs, but not sure if the lil' 4cylinder can handle it without just losing all power / mileage. So, any comments?
  2. Aug 24, 2011 at 12:12 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    What size are you looking to add? That's where the biggest difference is going to take place. If you stick with the stock size, are you getting E rated tires (10 ply)? If you keep the air down to a sultry 35 psi or so, it shouldn't make a huge difference. The weight will be a bit higher, but the rolling resistance will be roughly the same. If you go larger, it might suck more because you get weight and rolling mass (diameter)... Depends on what you are looking for. Personally, a mildly aggressive (read: Hankook Dynapro AT-M tire in a slightly larger size (read: 265/75r16) would be well worth the trade off. My girlfriend has those on her Jeep and they hook up really well, coupled with the fact that I have sold hundreds of sets of those with good on road reviews as well... That would be worth a slight sacrifice.
  3. Aug 24, 2011 at 6:13 AM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    I just went through this myself. I put 235/85R16's on my stock steel wheels. These are the same diameter as the 265/75R16's but are narrower. The tires I put on were 49LBS. This tire change took away 2-3 MPG and put my truck in a different power-spot for normal driving. It really drove me nuts. I "returned" the tires and got Michelin AT's in the stock size.
    I have had larger tires in the past and my last two sets of tires were BFG AT KO. I didnt feel that this truck with the 4banger was very forgiving with the larger tires.
    Lots of others are running larger tires and seem to have no problem. I felt the engine had enough power to do what I wanted, but I felt as though I was taxing the engine all the time with the 32" tires. The truck would go as fast as I wanted when i wanted, eventually, but I was down a gear if I wanted to have any acceleration at all.
    YMMV
  4. Aug 24, 2011 at 8:39 AM
    Hayes
    Brandon
    Denver, CO
    Hard and Hutch, you can regear to compensate for the loss in power. It's expensive up front, but everything we do to these trucks is expensive...
  5. Aug 24, 2011 at 8:45 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ill be running 78 lb general grabber red labels. (33x12.5x15) but im re gearing to 4.56
  6. Aug 24, 2011 at 8:51 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
  7. Aug 24, 2011 at 9:02 AM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I have the BFG All Terrains 265/75/16 on mine and they seem to do fine. I bought the truck with them on it so I can't say how it was before.
  8. Aug 24, 2011 at 2:17 PM
    hutch606
    Thanks for the replies. I'm not looking to go any larger, but wanted to know about going from a 35lb tire to 51. I know it won't improve power and mpg but curious if I'd hate myself for doing it. Thanks Hard for your take...
  9. Aug 24, 2011 at 2:28 PM
    Hard
    H
    4X4X4
    I would say you will notice a little difference but your truck will be geared properly with the stock size. The tires im running now are 46lbs, but the stock size, and i really like the power and ride. An aggressive tire in the stock size is all I will be using without a re-gear.
  10. Aug 25, 2011 at 1:55 PM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    I run load range E Safari TSR in the stock size, and with a couple of hundred miles a day (my 4 1/2 month old truck is going to turn 20k miles next week) worth of hilly logging roads, I'm averaging 19.75mpg, and have very seldom wanted more power--that's what the stick shift is for...
  11. Aug 25, 2011 at 2:05 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    I went from a 225/75/15 (28'') to Michelin A/T 31'' tires on my 2.7 Tacoma. I don't know how much of a weight difference there was but I only felt a slight difference driving. The larger tires actually lowered highway rpms and after the deckplate mod I am getting better mileage than when I had the smalled tires. You shouldn't have a problem with your 4 banger.
  12. Aug 25, 2011 at 2:17 PM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    I run 31" BFG KO's and my truck runs them fine. They was a set when I bought the truck so I don't have any comparison. But I can tell it's bogged down slightly, going from worn down BFG's to brand new ones. You will tell a slight difference. I still get great MPG's though!!
  13. Aug 26, 2011 at 9:36 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    im runnined 255/85/16 cooper st with moto metal 951. wheels weigh 20-30lbs more for all 4. the coopers iirc i read somewhere they are around 45-50lbs. I am over-geared to 4.56 and i am getting 24 mpg, 75% freeway 25% city
    so were talking close to 100 lbs more in rotation mass and im fine, truck hauls balls for a 4 banger
  14. Aug 28, 2011 at 12:49 PM
    Allen9621
    Allen9621 Active Member
    Northern California
    1996 4x4 5-speed
    Seeing as you only gain 1/2" of usable ground clearance for every 1" of tire height, I don't think larger-than-stock tires are worth it unless one truly needs that clearance.
    The 2.7L is just not up to the task when you push its capacity. I think it's a good balance of MPG to practical power but it's "underpowered" in comparison to many vehicles. Even the 4.0 V-6 will suffer driveability loss - you just don't feel it as much. The physics of rotating a larger tire mass and diameter can't be escaped, even with gear ratio matching. Most people seem to do it for looks over utility.
  15. Aug 29, 2011 at 6:43 PM
    hutch606
    Thanks for the input. As mentioned, no plans to go big, just retaining stock 245/75/16 tires; no need/desire for anything more. It was helpful hearing input on the 30% heavier tire. Thanks much!
  16. Aug 31, 2011 at 9:29 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    You didn't say if you were a 5-lug, but since you say you have a stock size of 245, I'll assume you're a prerunner or 4x4.
    I did notice drag moving up to duratracs in 265/75 (they're approx 45lbs a tire I think). It was still certainly driveable. The 4.10 gearing you have helps a lot, you'll be fine.
  17. Sep 10, 2011 at 6:11 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    255/75/17 firestone destination A/T on Fj cruiser wheels. Reg cab with the bil 5100 all four corners and front set at 1.75' . look real clean. Ill have to post some pics see what you guys think. noticed a slight drop in power and mpg but it looks good!
  18. Sep 27, 2011 at 4:58 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I have 265 75 16's bfg mud terrains (KM2's) on mine and its fine. At some point when I have an extra $1500.00 hanging around I will re-gear to 4.56's
  19. Oct 3, 2011 at 7:05 AM
    00PreRunner
    00PreRunner Well-Known Member
    New Albany, MS
    '02 TRD 4x4
    2002, auto to manual swap. 36 TSL's and 5.29's
    Manual tranny?
  20. Oct 26, 2011 at 1:32 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    You could also go TRD stock size 265/70/16 if you want to go wider (0.78") but not taller.
    I'll be going taller (1.18") & wider (0.78") 265/75/16 when I get my new tires.
