Hella 500 HID Conversion & Mount Behind Satoshi *How To* w/ pics
Discussion in 'Lighting' started by Klipp11, Mar 8, 2010.
  1. Oct 10, 2010 at 9:58 AM
    #141
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    see post # 50
  2. Oct 12, 2010 at 2:25 AM
    #142
    kauai808boy
    kauai808boy Member
    icon/fox 3inch lift, flow-master super 40, jba shorty headers
    when u run the hella with the hids instead of using the switch that came with the fog lights can u run the hid headlights to ur stock fog light switch?
    i have the ddm slim ballast 55w
  3. Oct 18, 2010 at 2:12 PM
    #143
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    How much time did you have doing this mod?
  4. Oct 18, 2010 at 2:51 PM
    #144
    Benny
    Benny Well-Known Member
    2008 DC LB more mods by the month
    What did you do with your horn?
  5. Oct 18, 2010 at 6:37 PM
    #145
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    a switch is a switch. any switch will work :)
  6. Oct 18, 2010 at 6:48 PM
    #146
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    give yourself the weekend and you should be fine
  7. Oct 18, 2010 at 6:51 PM
    #147
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Has anyone done this mod with the TRD S/C intercooler? You lose about 3"ish of clearance in front of the radiator.
  8. Oct 18, 2010 at 7:01 PM
    #148
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    i just removed them for a while, actually. i just put 'em back on over the weekend; i mounted them below the satoshi by the tranny cooler.
  9. Oct 18, 2010 at 7:09 PM
    #149
    Nick Sells
    Nick Sells Well-Known Member
    Elgin, South Carolina
    2016 TRD Off Road
    Bone Stock
    Those look awesome I wish I was confident enough to do the wiring but I'm not.
  10. Oct 18, 2010 at 7:11 PM
    #150
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    hey is 68 dollars for hella 500's good? for a pair i think
  11. Oct 18, 2010 at 7:16 PM
    #151
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    with 3" less clearance in front of the rad, i doubt you'd be able to satoshi the gc. but if you mount the gc flush with the front of the grill surround instead of recessing it, you could probably make it work.
  12. Oct 18, 2010 at 7:17 PM
    #152
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    it's easy. just follow the thread step by step and pm me with any ?'s :)
  13. Oct 18, 2010 at 7:21 PM
    #153
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
  14. Oct 18, 2010 at 7:26 PM
    #154
    johnw
    john
    orlando florida
  15. Oct 18, 2010 at 7:38 PM
    #155
    chyknees
    So Cal
    05 Tacoma TRD 4x4
    ok thanks. I just keep forgetting to go take some measurements and figured i'd post up and see.:)
  16. Oct 19, 2010 at 12:42 PM
    #156
    weiser5150
    weiser5150 Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    Klipp11....I did this exact same set up(thanks for the how to).I have vibrating lights when driving though.Do yours shimmy while you drive?
  17. Oct 19, 2010 at 6:39 PM
    #157
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    nope, mine are solid. i'd check all the bolts & make sure they're all nice and tight, especially the ones on the hellas where they pivot.
  18. Oct 20, 2010 at 4:11 AM
    #158
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Okay.....will do.Thanks
  19. Oct 23, 2010 at 2:19 AM
    #159
    chyknees
    So Cal
    05 Tacoma TRD 4x4
    Can anyone do me a favor and measure from the back of the light housing to the end of the pigtail on the hid bulb? Curious to see if I have enough room to do HID's on them.
    like on the right light
  20. Oct 23, 2010 at 4:27 AM
    #160
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Still vibrating.......I think my problem is i used 1/8" x 1" aluminum and
    you used 1/8" x 1 1/2" aluminum.
