Hella 500 HID Conversion & Mount Behind Satoshi *How To* w/ pics
Discussion in 'Lighting' started by Klipp11, Mar 8, 2010.
  1. Oct 26, 2010 at 5:15 AM
    #161
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    How did you get to the top row of switches without removing lower dash?
  2. Oct 26, 2010 at 6:25 AM
    #162
    weiser5150
    weiser5150 Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    run the wires up your dash and through the hole where you removed your blank. you'll find it easier if you remove the coin tray from the dash.
  3. Oct 26, 2010 at 7:33 AM
    #163
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Yeah, I did the same thing, couldn't stand the shaking. Went back with the 1 1/2 and remade my bracket. It did take out "most" of the shake, there is still a little over the rough stuff. I can live with the amount of vibes I now get.
  4. Oct 26, 2010 at 7:53 AM
    #164
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  5. Oct 26, 2010 at 5:20 PM
    #165
    NC15TRD
    Nick
    PA
    Well I can't even reach the upper row. Where the two halves of dash meet there's like a block there? If you know what I"m getting at.
  6. Oct 26, 2010 at 7:29 PM
    #166
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    been busy with work lately; i'll measure it for you on sunday and post for ya
  7. Oct 26, 2010 at 7:33 PM
    #167
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    i also used lock nuts and lock washers to keep those bolts tight
  8. Oct 26, 2010 at 7:36 PM
    #168
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    don't know about a block :confused: i just took the coin tray out and fed the wires up through the blank i removed
  9. Oct 26, 2010 at 9:12 PM
    #169
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Thanks. I appreciate it!
  10. Oct 27, 2010 at 4:42 AM
    #170
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Just feed the wires up and around that "block" and then grab the wires with some needle nose through the front of the blank.
  11. Oct 27, 2010 at 9:25 AM
    #171
    NC15TRD
    Nick
    PA
    Well how did you remove the blank?
  12. Oct 27, 2010 at 9:31 AM
    #172
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    with a small flathead.Did you read the instructions at the beginning of this thread?
    All your questions can be answered there.
  13. Oct 27, 2010 at 4:28 PM
    #173
    NC15TRD
    Nick
    PA
    Must have missed that! Got er now
  14. Nov 1, 2010 at 2:23 PM
    #174
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    Can anybody tell me if these are the regular hella 500 or the 500 ff
  15. Nov 1, 2010 at 7:13 PM
    #175
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    regular 500's
  16. Nov 1, 2010 at 7:14 PM
    #176
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    doing my black magics tomorrow!
  17. Nov 1, 2010 at 7:23 PM
    #177
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    you'll need 1" or more behind the plastic housing to clear
  18. Nov 1, 2010 at 11:59 PM
    #178
    chyknees
    So Cal
    05 Tacoma TRD 4x4
    thanks klipp!
  19. Nov 3, 2010 at 5:29 AM
    #179
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    are you upgrading them to HID?
    if so you will have to remove the metal "cross" inside the lights to fit the new bulb.
  20. Nov 3, 2010 at 6:30 AM
    #180
    PLC721
    Patrick
    Chandler, Az
    i was eventually planning to upgrade them to 4.5 k and yeah it looked like it when i examed them, thanks
