Hella 500 Question
Discussion in 'Lighting' started by mwerner1, Jul 10, 2010.
  1. Jul 10, 2010 at 1:13 PM
    mwerner1
    mwerner1 [OP] Active Member
    New Fairfield, CT
    09 Mag. Grey TRD Sport
    Rebadged, 20% Tint all-around, Alpine 9886 head unit, Infinity Kappa Component Speakers, MTX Jackhammer Amp, Extang SolidFold Bedcover, In-Channel Vent Visors, Satoshi Grille, Aux Lamps Behind the Grille, Bed Lights, HID Fogs, Yellow Lamin-X on Fogs
    So I installed my hella 500 black magics today behind the satoshi and got it all wired up. I didnt slice into the high/low beams like they said to cause i wanted full control of the lights so i just put the two power connectors onto the battery. Once I got everything hooked up and turned them on it didnt seem like they were as bright as i thought they were going to be. Did I do something wrong???
  2. Jul 10, 2010 at 1:15 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    there is no dim, its on or off, so no.
    seeing as how they are black magics they prob are not as bright as regular 500's, and it is hard to convert these to HID. good luck.
  3. Jul 10, 2010 at 1:24 PM
    mwerner1
    New Fairfield, CT
    alright, thanks just wanted to make sure that I wasnt doing anything wrong
  4. Jul 10, 2010 at 1:37 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I don't see why it would be any harder to convert these to HID. I would suggest investing in some higher power bulbs or HIDs. Mine were pretty dim at first too, but once upgraded they are really nice!
  5. Jul 10, 2010 at 1:53 PM
    mwerner1
    New Fairfield, CT
    What you upgrade to HID, or bulbs and if you did bulbs what kind???
  6. Jul 10, 2010 at 3:33 PM
    flightcancled
    Look at the stickies in this forum.
  7. Jul 10, 2010 at 5:08 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I had the regular 500s on my last truck. They definitely did not have the "WOW" factor by themselves, but they were fine to fill in the gaps in the high beam coverage. Make sure you take the time to aim them straight down the road. You might be okay with them after that.
