Hella 500 Wiring Problem
Discussion in 'Lighting' started by FrustrationFabTaco, Aug 17, 2012.
  1. Aug 17, 2012 at 6:55 AM
    FrustrationFabTaco
    FrustrationFabTaco [OP] Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    Yesterday I tried wiring up my hellas that i had converted to hid. They worked fine when I tested them just after converting. When I wired them into the truck they don't seem to be getting power. I've checked the connections countless times and cant find a problem, but there is obviously a big one. Any ideas?
  2. Aug 17, 2012 at 6:58 AM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    How did you wire it? One wire for ground (to frame), and one power wire going to ballast?
    Did you touch the ballast wire to the battery to see if it turns on before wiring to your truck?
  3. Aug 17, 2012 at 6:59 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
  4. Aug 17, 2012 at 7:01 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    yes, one from relay to ground, one from relay to ballasts, one from relay to switch, one from relay to battery. switch has direct power from battery, ground, and wire to relay. yes, the lights worked fine before wiring to the truck.
  5. Aug 17, 2012 at 7:02 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    an assumption.
  6. Aug 17, 2012 at 7:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Is there an in-line fuse somewhere in there?
    Also, what's triggering your relay?
    Lastly, I wouldn't have wired direct battery power through the switch. That could be your problem, you might have overloaded the switch. Did it get hot, any terminals melted?
    If you could put up a sketch of your wiring diagram, it would be helpful. As Brock said, using a test light to find out where you do and don't have power would help you out tremendously also. Test lights are cheap and available at any auto parts store.
  7. Aug 17, 2012 at 8:32 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I had the same problem when I converted my hellas to hid's. The converted hellas worked when I tested them (power straight from the battery), and the old wiring of my non-converted hellas worked. So it turned out that I was just getting a short that kept blowing fuses. Lilke said above check all ur grounds, make sure your connections aren't shorting (my 'butt connectors' were shorting-fixed after soldering them). Make sure your relay is not faulty.
    Post up some diagrams btw may help to see what's up.
  8. Aug 17, 2012 at 9:39 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    there are in-line fuses going from relay->battery and the battery->switch. The switch is fine, nothing melted or even got hot. ill get a sketch up in a bit
  9. Aug 17, 2012 at 10:00 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    sorry if its blurry, dont have a scanner so its from my iphone. if it means anything (i dont think it should) i took a chunk out of the middle and reattached the ends between relay->battery and relay->lights because they were incredibly too long. securedownload.jpg
  10. Aug 17, 2012 at 10:04 AM
    Pugga
    Massachusetts
    It looks like your wiring diagram is sound, so it's time to check and recheck all your connections and fuses.
    Make sure your relay is rated for the correct amount of power, make sure nothing is crossed, connections are secure, wires are plugged into the relay in the correct spot, etc. Once again, a test light would help you determine where you actually have and don't have power.
    Just a suggestion, there's nothing technically incorrect about your wiring diagram, but if you tap off of an existing circuit that's only hot when the truck is on, you can run that to the switch (leave out the in-line fuse because that base circuit is fuse protected). That way, you can't accidently leave the lights on, they'll shut off automatically when the truck is off.
  11. Aug 17, 2012 at 10:17 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    the relay is from the wiring kit that came with the hellas and all the wires going into the relay were already plugged in when i got it, the hids are 55 watt so its the same as the hellas would be normally. i dont think ill have a problem leaving them on, kind of hard to forget something thats so bright so ill probably leave the inline. time to check everything again :eek:
  12. Aug 17, 2012 at 10:24 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
  13. Aug 17, 2012 at 10:29 AM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Think your best bet would be getting a soldering iron kit. They are like 20 bucks are give you the best connections. Not hard to learn either
  14. Aug 17, 2012 at 10:30 AM
    CayucosTacoma
    2004 Double Cab 4x4
    Maybe pick one of these up to check your grounds.
  15. Aug 17, 2012 at 10:51 AM
    Pugga
    Massachusetts
    VV
    Soldering and heat shrinking your connections will give you the best connection. If you're set on using those crimp on connectors, at least heat shrink the connection if they're going to be exposed to the elements.
    You really need some way to check if power is getting through your circuitry. I would recommend getting yourself a test light. If you aren't even lighting up the switch, either the fuse is blown, the ground is bad, the connections are bad or you fried the switch.
  16. Aug 17, 2012 at 12:20 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    so i went through everything and replaced all the connections with the cap kind. found a blown fuse in the green wire (battery->switch) and then found that the relay was shot. used some extra wire to connect the battery wire that goes into the relay to the wire from relay to lights. everything works perfectly, just need a new relay. Thanks for the help guys. :cheers:
  17. Aug 17, 2012 at 12:23 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Glad you got it figured out. Enjoy the lights!
  18. Aug 17, 2012 at 1:15 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    one more quick question about the switch: i have it so it works fine but the light stays on constantly, can i make it so that the light is only on when the lights are turned on?
  19. Aug 17, 2012 at 1:19 PM
    Pugga
    Massachusetts
    Switch the wires on the switch. Keep the ground as ground, but switch the input and output wires and that should do it I believe.
  20. Aug 17, 2012 at 3:34 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
