hella 700ff from 55w to 100w?
Discussion in 'Lighting' started by beaver_scott, Dec 15, 2010.
  1. Dec 15, 2010 at 4:10 PM
    beaver_scott
    beaver_scott [OP] Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    anybody ever upgrade their hella 700ffs to 100w bulbs instead of 55w bulbs? the light output with the 55w bulbs sucks so I am thinking I'd like 100w bulbs. would the original wiring, relay, and fuse be ok to use for 100w bulbs? would the light housing be ok with a 100w bulb? I am electrically challenged so any help would be greatly appreciated!
  2. Dec 15, 2010 at 4:18 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I installed some vision-x 100w bulbs in mine and love it. Only a$ 30 upgrade.
  3. Dec 15, 2010 at 5:37 PM
    beaver_scott
    scott
    renton, wa
    and you didn't upgrade the wiring that came with the hella 700ffs?
  4. Dec 15, 2010 at 9:00 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    you are fine.
    although i recommend H83135312, hella's 100w performance H3.
    as with all bulbs make sure you spin the capsule in a paper towel soaked with isopropyl alcohol before installation. even if you don't touch the glass, some tiny asian somewhere might have.
  5. Feb 25, 2012 at 7:28 PM
    comajoe
    comajoe Well-Known Member
    rougemont, NC
    06 tacoma sr5
    bump
    i would love to do this, the 55w is lacking...
    its just a bulb change...correct?
  6. Feb 25, 2012 at 8:36 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Yes correct. I have some Vision X 100w like new bulbs for cheap. Let me know.
  7. Feb 25, 2012 at 11:14 PM
    Hii
    Hii Well-Known Member
    HIDs FTW
  8. Apr 15, 2024 at 5:39 PM
    TacoTuesday1
    SD CA
    700FF on order
    I think 100w>55w
    Do folks just slap any 100w halogen h3 in and call it good?
    hopefully whatever wiring and fuse comes with can handle it
    Heard it’s better for each light to use its own harness if 100w
    Guess I’ll find oit when they come if the harness in the kit is dual separate one for each light, or less parts and combines both into one…
  9. Apr 15, 2024 at 5:44 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Maybe. Do a simple check of the wire and fuse size to get a simple, actual, answer for yourself. Or just rely on the opinion of internet randos, fire can be fun and educational.
  10. Apr 16, 2024 at 1:06 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
  11. Apr 16, 2024 at 7:59 PM
    TacoTuesday1
    SD CA
    it looks like they might sell an HD harness at more cost separate
    what came with the 700FF is around 20 gauge and 15a fuse
    it’s much thinner than my headlight services headlights harness
    I imagine to up bulb from 55w to 100w might be needed change wiring to around 12ga and up fuse to 20amp, at minimum
