Hella H4 100/55w Halogen
Discussion in 'Lighting' started by TFLT, Jan 7, 2014.
  1. Jan 7, 2014 at 6:43 PM
    TFLT
    TFLT [OP] Active Member
    Central New York
    10 tacoma Reg cab 4x4
    Yellow Wire, Hella DE Fogs, Firestone airbags
  2. Jan 7, 2014 at 9:44 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have no idea about melting the plastic reflector and lens, but the wiring is marginal. 100W is about 8.5 amps, the headlights are fused at 10 amps each. I think it would work but the lights won't be as bright as they should be due to the thin wire Toyota uses at the lights.
    My gut feeling is it's too much heat for the reflector, too bad because I have run those bulbs in Hella housings and 100W high beam is pretty awesome.
  3. Jan 8, 2014 at 5:19 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    I put a set of almost identical Vision X bulbs (80w low/ 100w hi) in my wifes civic last week. Like Joes06tacoma mentioned, they are not as bright as they could be. But they are definitely brighter than the stock lights were.
    Longevity wise, I don't know how the heat will be around the reflector. So far so good, though.
  4. Jan 8, 2014 at 8:28 AM
    TFLT
    Central New York
  5. Sep 4, 2014 at 8:53 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    Did you install the 55/100w bulbs? I am thinking about doing the same on my Tacoma.
    I run the Narva version in my Cargo Van with cheap AutoPal H6054 conversion lights.
