Hella light switch wont light up
Discussion in 'Lighting' started by MotoXXX, Dec 7, 2009.
  1. Dec 7, 2009 at 7:41 PM
    MotoXXX
    MotoXXX [OP] Well-Known Member
    San Jose
    02 Pre-Runner
    I hooked up my hella lights and cant get the switch to iluminate? The lights work but the switch wont light up, I have one wire on the middle pin to the relay, one wire to the cigarette lighter hot wire and one wire grounded, I can switch the wires and iluminate the light but then the lights dont work? What did I do wrong?
  2. Dec 7, 2009 at 8:40 PM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
  3. Dec 7, 2009 at 9:47 PM
    MotoXXX
    San Jose
    02 Pre-Runner
  4. Dec 7, 2009 at 9:59 PM
    dktaco
    Josh
    Hmmmm....maybe some guys that are wiring guru's can chime in! Did you see if that switch will light up when not in a circuit with the relay?
  5. Dec 7, 2009 at 10:06 PM
    kiddwvman
    kiddwvman Well-Known Member
    leon
    WV
    06 4 banger
    weathertec floor liner,tinted windows,bilstein 5100 front .85,5100'S rear,window vents,K@N air filter
    when i had them on my jeep they only let while they were on ?????
  6. Dec 7, 2009 at 11:16 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    ground the 3rd terminal to a solid ground, 1 from relay, 2 to battery... should work
  7. Dec 8, 2009 at 1:24 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I had two and one of mine burned out. Hella sent me in a new one with a lot of e-mails and complaining. New one worked fine. Maybe the light in the switch is burned out like mine was.
  8. Dec 8, 2009 at 3:30 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    The light is probably out in the switch...happened to me on my Jeep. Test just the switch on a 12V source to see if it lights. You can get the three prong switches at radio shack or your local parts store no biggie.
  9. Dec 8, 2009 at 8:40 PM
    MotoXXX
    San Jose
    02 Pre-Runner
    Switch is good, if I switch the wires around it lights up but the lights will not! So I have one wire to ground (same ground as the lights), one wire to cig lighter for keyed power and on wire to the relay. I am stumped. will mes with tomorow.
  10. Dec 8, 2009 at 10:42 PM
    BlueSteel
    James
    The Woodlands, TX
    Check your connections on the relay and make sure that they are in the right order.
    30- fuse battery
    85- ground
    86- switch
    87- light (pos)
  11. Dec 9, 2009 at 6:19 AM
    MotoXXX
    San Jose
    02 Pre-Runner
    Will check it out asap, kinda wierd the lights work fine but the switch wont light up?
