hella lights behind grille
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco89, Jan 23, 2010.
  1. Jan 23, 2010 at 11:44 AM
    Taco89
    Taco89 [OP] Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    anyone have any pictures with hella lights behind grille? is it hard to install? any pics of installation?
  2. Jan 23, 2010 at 4:06 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Go look at your radiator support you will see 2 holes that are already drilled. You can just get the correct size bolt drop it through and toss the Hella's on.
    Thats one of the most popular ways on how to mount those lights.
  3. Jan 23, 2010 at 8:41 PM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    Search and you will find...
  4. Jan 23, 2010 at 8:44 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
  5. Jan 23, 2010 at 9:02 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
  6. Jan 23, 2010 at 9:54 PM
    burnt_tiger
    burnt_tiger Well-Known Member
    Bakersfield CA
    08 dbl cab 4x4 longbed
    viper 5900 automatic start/alarm, pioneer avic-d3 indash gps UWS black truck box black tube steps, blue sea fuse block wet okoles console vault AFE oil free drop in air filter. hose clamp mod 5% tint Cobra 75 CB
    do lights behind the grill (in front of radiator) cause the truck to run hotter? does it block airflow enough to cause a problem in hot climates?
  7. Jan 23, 2010 at 10:04 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Anyone know if you can fit 4x hella 500's back there? Everyone that has 2 it looks like there's enough room for 2 more if you did it right.
  8. Jan 24, 2010 at 12:59 AM
    1BlkT
    Ty
    90603
    I've driven mine in 105 degree heat for about 1 1/2 hours and didn't see any change in temp. My grille material is also perforated and the holes are a bit on the smaller side, the grillcraft openings are bigger than mine just for reference.
    Not sure if you can do 4 or not, I haven't seen it yet. I wanted to do 3 but then I realized there is the hood latch support that goes down the center so I didn't want to bother messing with that.
