Hello friends
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoreysIRTaco, Jun 13, 2020.
  1. Jun 13, 2020 at 7:27 PM
    CoreysIRTaco
    CoreysIRTaco [OP] Well-Known Member
    Corey
    2004 Tacoma DC TRD
    None
  2. Jun 13, 2020 at 7:27 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome, yes is the answer
    CoreysIRTaco[OP] likes this.
  3. Jun 13, 2020 at 7:56 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Same lug pattern but will sit noticeably further inside the wheel well, as in closer to the the frame and suspension.
    I run stock size 265/70R16 Michelin on 2nd gen wheels and they get close to the upper arm when suspension cycles, but do not make contact. I've read of some having issues with rubbing, even with stock size. Mine don't though and I think most stock size tires don't.
  4. Jun 14, 2020 at 9:06 AM
    wesheppy
    wesheppy Member
    Weston
    1998 Tacoma 4x4 4in Lift
    Spc upper control arms Eibach springs Bilstein shocks Rear shackles
    Yep i have a 98 with 3rd gen wheels and 265/75/16 tires on it but it rubbed on the uca when cycling the suspension so i put 1.25'' wheel spacers on and that fixed it. Newer wheels have less offset than older wheels.
