Hello from Canada - need guidance with radiator issue
Discussion in 'Technical Chat' started by House, May 1, 2008.
  1. May 1, 2008 at 4:38 PM
    House
    House [OP] Member
    Ontario
    08 SR5 4X4 AUTO 4.0 Access Cab
    Long time lurker first time poster.
    Love my truck. I've had her for about a month now. I'm at about 2,600 km. Like many others here, I've got the engine tick, brake shudder, acceleration / deceleration shudder, and the driveline clunk when stopping and taking off. I'm looking after this stuff.
    But today, when I opened the hood to check the oil (that's right), I noticed crystalized rad fluid all over the radiator cap and hose, and there was some spray on other areas of the motor.
    Has anyone else come across this? Any ideas what may cause that kind of pressure? Of course I'll talk to my dealer, but I want to do my homework first.
  2. May 1, 2008 at 7:07 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Hi House....Can't help you with the issue but welcome from NB.
  3. May 2, 2008 at 4:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Obviously you're still under warrantee.....
    Have you checked your overflow bottle level? Make sure you have enough in there... since you're losing fluid.
    You can either take the truck immediately to the dealer and have them look at it..... Or.... You can clean up all the residue, check under the hood everyday and see if you can determine where its coming from.
    Could be anything - loose hose clamp, bad radiator cap, anything....
    Personally - I'd take it to the dealer myself. You've paid for that warrantee, now make them do the work.
    Good Luck!
  4. May 2, 2008 at 5:35 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I completely agree with Janster. It's a new truck and it's not right. Head right back to the dealer with it.
  5. May 4, 2008 at 11:03 AM
    House
    House [OP] Member
    Ontario
    Thanks guys. I'm at the dealer on Tuesday for an oil change. I'll get them to take a look at it then. It looks like the leak may be coming from the clamp on the overflow hose - this is where the bulk of the solid coolant seems to be.
  6. May 4, 2008 at 1:09 PM
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    I had the same problem with rad fluid crystalizing around the cap and just down the neck of the resevoir, I noticed that it was about a half inch over the full line on the resevoir so I drained it down to the full line and havent had it happen since!
  7. May 4, 2008 at 1:12 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Welcome to TW!
  8. May 6, 2008 at 4:09 PM
    House
    House [OP] Member
    Ontario
    So I went to the dealer for the truck's first oil change. I'm running Mobile 1 5W30 with a Toyota filter (no M1 filters in stock). I was hesitant to switch to synthetic "early" (3000 kms), but it was going to get done eventually, so why not get it out of the way now. If there was break-in oil, it's at the bottom of the oil drum. The tech was pretty good. He took me into the bay and showed me how to drain the filter oil without getting oil all over the place. He also pointed out all the lube fittings.
    And no, there was no consultation charge for the extra service (LOL...I checked).
    As for the coolant issue originally posted, he cleaned the area and secured the overflow hose. He had no idea why it happened and told me to keep an eye on it. I can accept that....for now. Things happen.
    Stay tuned for an update on de-badging and de-flapping. Hell, I may even add some speed holes.
